electrical boost gauge question
Old Feb 9, 2010 | 09:27 AM
darkmitsu's Avatar
Is it possible to wire an electrical boost gauge into the factory mitsubishi evolution X 3.3 bar map sensor and get reading from there rather than using the map sensor that comes with the gauge?
Old Feb 9, 2010 | 09:48 AM
NZEvox's Avatar
technicly it is posible. but you would run the risk of interferring with the ecu that allso reads that sensor
Old Feb 9, 2010 | 10:02 AM
darkmitsu's Avatar
so does an electrical boost gauge auto calibrate to what ever map sensor you plug into it , or is it calibrated for the map sensor that it comes with...
