51520020 EVO X RS definition file
Old Feb 8, 2010 | 12:33 PM
Caufield's Avatar
Hello,
I can not read the above rom file, can anyone help ? The car is 2008 USDM EVO X RS.
Old Feb 8, 2010 | 01:28 PM
SiC's Avatar
SiC
I have never seen this ROM before, are you sure it's an USDM? If you can upload it somewhere, I may be able to help you make an XML for it.
Old Feb 8, 2010 | 02:14 PM
Caufield's Avatar
link
Hello,
here is the download link
http://rapidshare.com/files/347886314/EVO_X.hex.html
I am very thankful for your help.
p.s. Here is what ECUflash is telling me
Old Feb 8, 2010 | 03:25 PM
SiC's Avatar
SiC
Originally Posted by Caufield
Hello,
I keep getting this when I try to download:
Currently a lot of users are downloading files. Please try again in 2 minutes or become a Premium member
or this
Unfortunately right now our servers are overloaded and we have no more download slots left for non-members. Of course you can also try again later.
Old Feb 8, 2010 | 03:35 PM
SiC's Avatar
SiC
Okay, I finally downloaded it and the ROM ID is not what you say it is. The actual ROM ID is 53040008. Rename the attached file to 53040008.xml instead of txt.
File Type: txt
Old Feb 8, 2010 | 03:36 PM
Caufield's Avatar
or this
Can you pm me your email, so I can send it to you ?
Old Feb 8, 2010 | 03:47 PM
SiC's Avatar
SiC
Put the file I posted in your Evo XML directory and you should be fine.
Old Feb 8, 2010 | 03:51 PM
Caufield's Avatar
Fantastic, thanks a lot SiC !
Can you tell me how can I see the real Rom ID if I encounter the same situation again ?
Old Feb 8, 2010 | 05:24 PM
SiC's Avatar
SiC
You'll need to open up the ROM in a hex editor and look at the address 5002a.
Old Feb 9, 2010 | 12:11 AM
Caufield's Avatar
Cheers SiC
Old Feb 9, 2010 | 11:16 AM
GST Motorsports's Avatar
Actually you don't need to do that at all:
You can find out the ROM ID by opening it in ECUflash, when it says "unknown rom image" select "use wizard" then select "copied from def below", then I usually select 52680015 (You can select whatever you want, it doesnt matter) then on the next screen it will show the ROM ID under "identifier"
Then you can cancel the wizard and find the proper ROM ID XML or create one.
- Bryan
Old Feb 9, 2010 | 12:04 PM
Caufield's Avatar
- Bryan
Cheers to you Bryan
Old Feb 9, 2010 | 01:35 PM
SiC's Avatar
SiC
- Bryan
Ah, I never really used the wizard so I wasn't aware of that
marinos
Mar 13, 2015 10:17 AM
mitsevolution
10
Jun 7, 2011 07:28 PM
NICK(PMR)
Oct 4, 2010 09:54 AM
MC-Tuner
Sep 21, 2009 02:00 AM
blackvr
20
Apr 10, 2009 01:45 AM
