P0302 with cobb stage 1
Old Feb 22, 2010 | 09:27 PM
WD40's Avatar
Hi,
Ive had my X MR for just over a year from new and i fitted the Cobb Accessport around 6 months ago and ran the Stage 1 map. It is now throwing up the P0302 code only when the stage 1 map is in. If i revert back to stock it does not happen. I realize its a misfire with the cylinder 2 but i dont understand why it only throws up the code when i have the stage 1 map in?
Car is stock apart from this
Any ideas
Old Feb 22, 2010 | 11:01 PM
SiC's Avatar
SiC
Pullout the spark plugs and inspect them for damage. Damaged spark plugs may have a harder time firing under higher pressure so it may run okay with the stock map but under higher boost of the Stage 1, it may misfire.
SOG RA
34
Sep 17, 2015 09:14 PM
FlipSquad
Cobb AccessPORT
May 14, 2015 03:18 AM
tkrizzy3
Dec 2, 2014 02:58 PM
antyoo
Cobb AccessPORT
Mar 21, 2014 09:47 AM
awdfun
Cobb AccessPORT
Feb 9, 2014 11:41 AM
