Front O2 sensor voltage offset?
Old Mar 14, 2010, 07:47 AM
Fourdoor's Avatar
Hey guys, (Tephra specifically)
ROM ID 55590006
I am running E-85 and would like to lean out my idle and cruise A/F ratio's for improved fuel economy. I could do this by changing my injector scaling a bunch more, so my STFT and LTFT's were maxed out and unable to change fueling... but a more elegant solution would be to change the voltage offset of the front O2 sensor by a small amount. This would lean out (or richen, depending on value entered) the fuel delivery any time the car is in closed loop operation, but it would still be able to compensate for weather changes etc with the fuel trims.
If anyone can figure this one out, much appreciated!
Keith
Old Mar 14, 2010, 11:24 AM
stokEd's Avatar
Can this not be accomplished by tweaking the fuel maps?
Old Mar 14, 2010, 04:48 PM
tephra's Avatar
yeah but you would need to run openloop full time to get the same affect - which probably isn't advisable...
after thinking about this, I dont think you will be able to do what you want WITHOUT replacing the narrowband with a wideband.
mainly because the narrowband only detects stoich - so once you apply the offset it will run lean/rich and the narrowband will say that rather than stoich...
its a bit confusing, but I dont think it will work...
Old Mar 14, 2010, 05:45 PM
Fourdoor's Avatar
If you can give me the code I will test it out and let you know if it works or not.
Keith
Old Mar 14, 2010, 06:26 PM
Golden's Avatar
It would be interesting to run a WB and a value outside of stoich. I think better economy would be had around 15.2 afr, plus I would like to have my WB not jump around so much in open loop. I'll have to try this some day.
Old Mar 14, 2010, 08:42 PM
criptballer's Avatar
i accomplished leaning out my idle by dialing in my LTFT as close to 0 as possible and then my car goes into open loop after my STFT are at 0. so i have my idle at 15.3
Old Mar 15, 2010, 09:34 AM
stokEd's Avatar
Understood, thanks.
jvaz1985
Dec 14, 2014 04:13 AM
92LaserRs
Apr 15, 2011 12:56 PM
fid
Mar 16, 2009 07:25 PM
batmoEVO
11
Jan 28, 2008 05:31 PM
Quick Reply: Front O2 sensor voltage offset?
