anyone tried loading the 2010 ROM onto an 08?
Old May 16, 2010 | 05:39 PM
E6-X's Avatar
tephra can this be flashed onto mine ? if yes send me the rom. u got my email rite...
Old May 16, 2010 | 05:49 PM
jrsimon27's Avatar
Originally Posted by tephra
your only going to get more power if your still on the stock tune..
and the only reason you would be on the stock tune is to keep your warranty..
and doing this would "void" that warranty anyways
yep this what i want more power on a stock tune
Old May 16, 2010 | 07:01 PM
tephra's Avatar
well you can't do it without a ECU bench kit...
the power increase is going to be bugger all over a proper tune anyways..
Old May 16, 2010 | 07:45 PM
jrsimon27's Avatar
well i do have evoscan and ecuflash
Old May 16, 2010 | 07:57 PM
tephra's Avatar
you need a proper bench - ie lots of wires that connect from the OP20 + power + ground to the ECU..
its not worth the trouble..
are you concerned about warranty?
Old May 16, 2010 | 09:30 PM
gunzo's Avatar
1st 8k also contains ETACs and variant code information ..
there's differences in the variant coding between the 08 and 10 .. you may get variant coding error
Old May 16, 2010 | 09:36 PM
tephra's Avatar
well it's interesting... in the AUDM 2010 ROM the first 8k is the same as the 08/09 AUDM ROM..
but yeh USDM is different...
Old May 16, 2010 | 09:50 PM
gunzo's Avatar
Variant codes include un/availability of certain functions .. that could have already been available on the 08 models for EDM/AusDM
Old May 16, 2010 | 10:03 PM
tephra's Avatar
well personally I think upgrading to the 2010 ROM will probably be fine for the 2008 car.
HOWEVER due to the painful nature of the upgrade (ie you need to bench the ECU) its not worth the hassle.
Thus I will be doing a tephramods for 2008 and 2010
Old May 16, 2010 | 10:06 PM
NZEvox's Avatar
Thanks heaps
Old May 16, 2010 | 10:49 PM
acamus's Avatar
From: Lattitude 48.38°, Longitude 17.58°, Altitude 146m = Slovakia, for common dude
Any details you may share or point me to discussion about this issue?
Old May 16, 2010 | 10:51 PM
E6-X's Avatar
so does that means for 2010 rom's can be flashed directly onto audm and edm specs since the 1st 8k line is same ? interesting on what mitsu is doing.
Old May 19, 2010 | 01:55 PM
EvoXtasy2010's Avatar
GST the last .xml file on that link is broken. Can you provide?
Old May 19, 2010 | 01:58 PM
GST Motorsports's Avatar
Works for me. Right-click "save as"
- bryan
Old May 20, 2010 | 08:21 AM
Golden's Avatar
Or "View Source"
