HOW-TO: Bench ECU (w/ Pictures!)
Old Apr 8, 2010 | 09:08 PM
Koroshiya's Avatar
HOW TO: Polish a turd, aka fix a brick, aka bench your ECU
Author: Saiba Samurai (***************) / Koroshiya (evolutionm.net)
Special Thanks: Tephra, celica2evo, & my wife for ****ting a brick!
Parts Required
  • Few feet of 20-24 gauge wire (preferably different colors, I recommend 24 gauge)
  • 0.1" female connectors (Need at LEAST 15)
  • Heat shrink tubing or electrical tape
Tools Required
  • Brick (aka ECU)
  • Tactrix Cable
  • Power Supply
  • Wire Cutters
  • Crimpers
  • Soldering Iron (optional)
  • Heat Shrink Gun or Small Lighter (optional)
Recommended Number of People[/LIST][*]1 (+1 to taunt you incessantly about how the Evo is supposed to be a tuner friendly car…)[/LIST]
Difficulty
  • 3 (10 if you drink a beer for every connector you make)
Time to complete
  • 30-60 minutes
Step by Step Instructions
  1. **** a brick.
  2. Be a real man and make a pile of them!
  3. Correct your grammar. ****, a brick! (If you don't get this, stop here, you can't handle this.)
  4. Create a group of wires to power the ECU
    ECU Pins:
    71 -> GROUND
    82 -> +12V
    92 -> +12V
    104 -> +12V
  5. Create a group of wires to power the ODBII
    OBDII Pins:
    4 -> GROUND
    5 -> GROUND
    16 -> +12V
  6. Create a group of wires to connect the ECU to OBDII
    ECU to OBDII Pins:
    ECU 80 -> OBD 7
    ECU 90 -> OBD 6
    ECU 91 -> OBD 14
    ECU 103 -> OBD 12
  7. Connect the wires to the appropriate pins
  8. Hook it up to a 12V Power Supply.
  9. Choose "Alternate flash method" in ECUFlash options.
  10. Load up your “Last Known Good ROM”
  11. Flash your Last Known Good ROM - this will take at least a minute.
  12. Now deselect "Alternate flash method" in ECUFlash options.
  13. Flash your “Last Known Good ROM” AGAIN (This will configure the ECU properly.)
  14. Stick the ECU back in the car - it should work properly!
Old Apr 8, 2010 | 09:09 PM
Koroshiya's Avatar
Random Pictures
Old Apr 8, 2010 | 09:21 PM
Koroshiya's Avatar
Reserved.
Old Apr 9, 2010 | 05:49 AM
detroit pistins's Avatar
nice work koroshiya!
Old Apr 9, 2010 | 05:56 AM
bigric09's Avatar
your little test bench looks like my office at work lol
good job, wanna come to my place and help me with the rest of the entire electrical system ?
Old Apr 9, 2010 | 01:33 PM
Koroshiya's Avatar
Haha Hey Jason if I could give you a hand I would. Let me see if I can get through my Chem work then I'll come over and lick wires to find the power for you.
Old Sep 3, 2010 | 02:35 PM
voodooman79's Avatar
Can you use this method to just put the ecu back to stock? I think i have done something terribly wrong and I'm trying to undo any XML mods I did on my laptop that, "of all things" CRASHED a few days ago and I lost all of my modded XMLs. How can you just put my evo x MR back to stock everything?!?
Old Sep 3, 2010 | 03:13 PM
limvolution's Avatar
good stuff
Old Sep 3, 2010 | 07:00 PM
Golden's Avatar
Simply flash a stock ROM back. But the changes are in your ROM, not the XML definitions.
Just Read the ROM off your ECU and get new definitions. Simple. Done.
Old Feb 22, 2011 | 06:13 PM
LCEvo's Avatar
Is this the same for evo 9
Old Feb 25, 2011 | 07:23 AM
ferocus's Avatar
God bless you !
"The operation completed successfully."
Old Apr 6, 2011 | 09:46 AM
ekizenbe's Avatar
I used the how to as well to unbrick my ecu. After I flash in my stock map and load it into the car. The car still has the fans blazing away and all the check lights popping up on the dash. I dont know what to do. The car will also not crank at all. Can somebody help please?
Old Apr 7, 2011 | 09:00 PM
kozmic27's Avatar
Posted he found a bent pin in another thread. I think its fixed now.
Old May 13, 2011 | 07:37 AM
view's Avatar
The regulador is the 12v,.żand the amp 7,5A o more?
Thanks
Old Sep 12, 2011 | 05:40 AM
masafina's Avatar
Thanks, works for me
