ecu error codes
Old Apr 14, 2010 | 03:54 PM
dadsgts's Avatar
ecu error codes
flashed my stock gts ecu and was given two codes p0098 which i think is intake sensor and p0365 which is the exhaust cam sensor. it ran fine for about two minutes then studder and wouldnt go over 3000 rpms. any ideas how to fix this or can anybody give me a xml file for my lancer gts.. thanks
Old Apr 14, 2010 | 04:47 PM
tephra's Avatar
sometimes after a flash I get the intake temp sensor, so you can clear/ignore that one.
but 365 is weird.
i would clear it and see if it comes back...
pcmscan/evoscan beta to clear DTC's
Old Apr 15, 2010 | 04:07 AM
dadsgts's Avatar
errors
i did try delelting them and they came back. i was wondering if the evo's change in cams would make that much effect on a na car. Would changing my lancer gts fuel maps to an evo x and leaving the timing alone allow enough change to run a turbo safely or is the timing a large part of it?
thanks
Old Apr 15, 2010 | 05:04 AM
tephra's Avatar
take it in for warranty...
or is your warranty out?
dadsgts
42
Jan 23, 2021 06:06 AM
DaBaum
Apr 8, 2016 06:46 AM
Broxma
Aug 1, 2010 03:33 PM
09_Lancer_GTS
Lancer Aftermarket Forced Induction Tech
Jul 16, 2009 08:13 PM
Evodreamer28
Lancer Troubleshooting
Nov 25, 2008 10:48 AM
