Injectors
Old May 3, 2010 | 04:26 PM
Evofreak21's Avatar
Injectors
Im looking to go with E85 but I trying to figure out what injectors are the best for my set up? Looking for the injectors to support between 400-500hp with a single walbro 255. What I have seen is the FIC 1150, ID1000 and the DW1000. What are everyone using and have success with?
Old May 3, 2010 | 04:54 PM
H Jensen's Avatar
Ive seen people run the DW1000s a bunch but, take a moment and look at the dyno results in here and find the ones using E85 and what injectors there using.
Old May 3, 2010 | 05:09 PM
Evofreak21's Avatar
I dont think they are even making the DW1000 anymore. I believe they jumped to 1500, not sure how to get a set though.
Old May 3, 2010 | 05:45 PM
tephra's Avatar
a single walbro (255L/h) will max out at about 1050cc/min
personally I would probably go with the FIC's..
whatever is plug and play - i dont really think you can go wrong...
Old May 3, 2010 | 05:46 PM
GST Motorsports's Avatar
The FIC's are not plug and play sadly..
- Bryan
Old May 3, 2010 | 05:48 PM
tephra's Avatar
I thought you could option them to have PnP connectors?
Old May 3, 2010 | 05:58 PM
Yes, I guess that means PnP but with a pigtail.
- Bryan
Old May 3, 2010 | 06:00 PM
Evofreak21's Avatar
Will a single walbro get me between 400-500hp.
Old May 3, 2010 | 06:01 PM
tephra's Avatar
http://www.fuelinjectorclinic.com/cg...ey=IS127-1100H
Includes pigtails PGTJETR4 or add P&Play adaptors PADPJtoD4.
Old May 3, 2010 | 06:05 PM
tephra's Avatar
http://www.injector.com/injectorselection.php
yes... theoretically!
Old May 3, 2010 | 09:16 PM
Golden's Avatar
I have FIC 1100.
Very easy to tune and no warm start / idle issues. MrFred has a post on here about them. There is also a post in this section too.
I used tsitalon1's scaling and made a minor tweak to them. Car started perfect the first time on both pump and E-85.
https://www.evolutionm.net/forums/ec...injectors.html
https://www.evolutionm.net/forums/ev...xperience.html
Old May 4, 2010 | 07:40 AM
ohitisethan's Avatar
i have dw 1000 with e 85 and 93 works beautifully sometimes it may have a rough start up but just for a few seconds.
Old May 4, 2010 | 08:31 AM
HiI'mDustin's Avatar
To get 500whp you will need a double pumper....
the ID 2200 would be a better injector since you will run the ID 1000s at 97% at wot at around 450whp
this is all assuming you are talking about a dynojet....if you are talking about a mustang dyno then you will have to have ID2200 and a double pumper
If you want 450whp ID1000 and a double pumper should be fine
Old May 4, 2010 | 08:49 AM
fostytou's Avatar
EvoM Community Team
Well played
Old May 4, 2010 | 09:01 AM
mlomker's Avatar
Yup. Welcome to the problem that everyone running E85 on a stock-framed upgrade turbo has...either you leave power on the table or you go mass overkill on your fuel system.
