throttle problem
Old May 22, 2010 | 08:13 AM
student_scheire's Avatar
Monday I'll return to my friend with the Dyno and I'll try to find a solution.
I'll make a report of it
Old May 22, 2010 | 11:55 AM
Thumbs up
Originally Posted by tephra
you should just disable the airflow checks...
I've found a secondairy flow check table but I don't know how to put it correctly in the xmls... the original map starts at 0x60A8D
the other flow check table (probably the cause of the error) starts at 0x63BBB... (found with hex editor :d)
I've added a second table to the evo10base and one to the 53040007 but the errors keep comming in ecuflash... anyone a tip?
53040007(added under the airflow check table):
<table name="Flow Check table #2" address="63BBB">
<table name="Load" address="62a78"/>
<table name="RPM" address="62a60"/>
</table>
evo10base (added under the flow check table):
<table name="Flow Check table #2" category="Limits" type="3D" swapxy="true" scaling="ISCVSteps">
<table name="Load" type="X Axis" elements="21" scaling="Load"/>
<table name="RPM" type="Y Axis" elements="9" scaling="RPM"/>
</table>
Old May 22, 2010 | 05:58 PM
tephra's Avatar
no...
using the DTC disables
Richard.Son
Apr 24, 2016 10:10 PM
Benja
10
Mar 2, 2014 05:03 AM
richardjh
Jun 18, 2011 10:16 AM
GTR2009
12
Jul 22, 2009 12:46 PM
Graphite_MR
34
Oct 2, 2008 01:00 PM
