Stock EVO 8 injectors "vs" RC Injectors
Old May 20, 2010 | 10:26 AM
Supraguy31's Avatar
Registered User
I know that this is a long shot but I need some information from people here.
I was wondering if there is a Big Difference between the Stock EVO 8 560cc Injectors and the RC 550cc Injectors. Reason for asking is that there are alot of People in the toyota Supra forums that use RCs but these look like a better Injector because of the 4 nozzle Spray Pattern.
One of the members from there are Selling these 560cc (Red or Pink looking) injectors (Part number MDL560P if that helps) staying that they will flow just as well as the RC 550cc Injectors that everyone is using.
Before I purchase a set, I would like to hear it from you all. Will the Stocker EVO 8 do just as well as the RCs. How is the flow versus a single spray pattern like RC 550s have, and Basically, Would you recommend them as a Upgrade to the 87-92 Supra turbo guys. Stock injectors on there cars are 440s
Also, Is there a Upgraded injectors in the same style that you all use if I wanted to go larger than 560cc but in the same 4 port spray pattern?
Any Advice would be greatly Appreciated.
Old May 20, 2010 | 10:30 AM
derekste's Avatar
wrong forum sparky
Old May 20, 2010 | 12:45 PM
fostytou's Avatar
EvoM Community Team
This is the evo X section
The spray patterns will be one difference, but probably more important are latency and dynamic flow. Dynamic flow is probably very good on an OEM injector, but no one here probably has the tests to show that one is better than the other.
http://www.ecmtuning.com/wiki/baseinjectordata?s=e85
That link may or may not help you out, but relaly they are rated similarly and should flow similarly. If you can tune the latency properly and connect them easily then they should probably run very similar at a flow rate that low.
Old May 20, 2010 | 06:55 PM
Supraguy31's Avatar
Registered User
Sorry about the wrong Forum. I posted it over in the right area... Sorry about that guys and gals
Fast_Freddie
Oct 30, 2023 01:56 AM
SnailSpeed
Sep 22, 2019 02:20 PM
splattj
Apr 11, 2017 12:13 PM
jameswwt
Dec 16, 2010 12:27 AM
dudical26
23
Apr 13, 2007 03:39 PM
