Stage 2 Boost Restrictor Pill Question
Old May 24, 2010 | 11:53 AM
Optiblue's Avatar
Hi guys, I removed my stock boost restrictor pill awhile ago and forgot which way it goes back in. Does anyone happen to remember?
Thanks.
Old May 24, 2010 | 03:22 PM
Golden's Avatar
Are you asking which hose?
Direction doesn't matter.
Old May 24, 2010 | 03:37 PM
Optiblue's Avatar
I'm asking which way the pill goes back in. Direction doesn't matter? But the pill looks different on each side.
Old May 24, 2010 | 04:53 PM
zerocooll21's Avatar
Go to Cobbs website and look for the stage 2 instructions, it will tell you have to remove the boost pill. You should be able to follow it backwards.
http://www.accessecu.com/accessport/.../EVOXMaps.html
Hope that helps.
Old May 24, 2010 | 05:52 PM
Optiblue's Avatar
Thanks, and I wish it were that easy! They don't have actual pics of the pill for our cars
Old May 24, 2010 | 06:21 PM
Golden's Avatar
It's a small hole. The direction of flow won't matter, as long as it restricts flow. The direction of flow will be towards the intake, so if one way looks like it would work better, go ahead and stick it in that way.
Old May 24, 2010 | 09:08 PM
Are you sure?? That looks like a evo to me, am I missing something? Sorry if its not I thought it was
Old May 24, 2010 | 09:24 PM
Golden's Avatar
He doesn't mean the location of the pill. He means the Pill itself.
It doesn't matter which way it goes in. It just restricts flow.
Old May 24, 2010 | 09:26 PM
Ohhhh LOL my bad!! Does the pill look the same on both ends?
Old May 24, 2010 | 09:28 PM
Golden's Avatar
Not really, no. It looks a bit like a funnel, bigger opening at one end and a small hole on the other.
Old May 24, 2010 | 09:32 PM
Does the air flow passing through the pill only go in one direction? If that's the case then it should matter which way you put it in. Am I missing something?
Old May 24, 2010 | 09:46 PM
Optiblue's Avatar
It looks like a concave funnel on one end, and the other side is flat. Which side does the funel side go? I took a piture way back when on my iPhone, but it crashed and had to do a full restore so my reference pic is gone! I hope someone remembers, I've already put it back in with the funnel side towards the engine, but it would be nice to know what it should be!
Old May 24, 2010 | 10:37 PM
SiC's Avatar
SiC
From the shape of it, I would assume that the larger side go towards the turbo and the smaller end goes towards the solenoid. It really shouldn't matter too much even if you put it in wrong but if you are worried, pull out the restictor pill from the other solenoid and see how that was facing. Both pills should be facing the same direction.
Old May 25, 2010 | 05:26 AM
Optiblue's Avatar
Great! That's how I have mine now. Thanks everyone.
Old May 25, 2010 | 05:47 AM
EvocentriK's Avatar
I believe SiC is correct - the conical side faces the direction the airflow is coming from ie: turbo. I'm pretty sure I read somewhere that is helps control the flow through the restrictor.
