EVOScan problems
Old Jun 2, 2010 | 10:16 PM
marinos's Avatar
Originally Posted by Golden
It's the market the car is sold in. I'm not sure what all markets there are, but here are the ones I know:
USDM = USA
JDM = Japan
EDM = Europe
ADM = Australia
There is another for middle eastern, I think.
Grece is european country so probably EDM
Old Jul 5, 2010 | 04:57 PM
brocksdad's Avatar
Different car, same kind of problems. Still ECU 55570005
If I use mode 23, I can only look at about 10-12 parameters and they are not accurate. Coolant temp is 85* F, IAT is 33* F, manifold air temp is -40* F. STFT is at -25% and LTFT is about 6%.
If I switch over to EVO X on the Select ECU tab, I get more parameters, but they are still wrong. TPS shows about 96%, Coolant temp and IAT are identical 174.2* F. If I activate the battery level, TPS starts to work.
I am using Windows 7 64 bit and EVOScan 2.7.
I have tried to use a Windows XP machine and it does the same thing.
Old Jul 5, 2010 | 10:10 PM
Golden's Avatar
Well, first off, that equation for temps is in C not F.
It needs to be 1.8 * x - 40 for F.
STFT needs to be at 238088b0
You have the right settings selected. You just don't have the correct definitions. On the other site, I posted up all this information. You can just google "official 55570005" and find my thread on the subject. All you need is in there.
Old Jul 5, 2010 | 10:50 PM
brocksdad's Avatar
Thanks for the info. I will try this in the morning.
Old Jul 6, 2010 | 09:41 AM
brocksdad's Avatar
I got the files from the other site and put them in the appropriate places. I am still only able to look at the same logging parameters. I looked through the .xml for Mode23 and there are quite a few more things parameters than what I am showing.
Mode23 is enabled.
Old Jul 6, 2010 | 10:26 AM
brocksdad's Avatar
I had originally only put the Mitsubishi EvoX Mode23 USA.xml into the data folder in EVOScan. That was only allowing me to log the same 12 pararmeters. I then put the data.xml in the same folder and I get this:
I have since removed the data.xml and I keep getting the same thing. I uninstalled and reinstalled EVOScan and the same thing is happening.
Old Jul 11, 2010 | 03:55 PM
erniebu's Avatar
Man... still having the same issues... hope you get them worked out, I'm planning on heading back to AZ in Aug...
Old Jul 12, 2010 | 09:34 AM
Golden's Avatar
Try setting up your RomMetaData folder again. There are weird issues with the newest Windows stuff.
Old Jul 24, 2010 | 03:09 AM
evoscan's Avatar
Silver Sponsor
data.xml file contains all the same ecus as whats in the other xmls files. if you are going to try and use an old data.xml then you should remove those other duplicate xmls. it will actually load the data.xml file first I'm sure, and that message is just a warning just to let you know that you have doubled up on the ecu configuration in your datasettings folder. its, not a fatal error.
if you open up all the xmls in that folder you will see that you have done exactly what the message suggests, and that you have defined the same ecu more than once.. once in the data.xml and once in the Mitsubishi MUTII.xml file.
and if you removed it, then you probably forgot to check you virtual store folder... you should use EvoScan v2.7.0070 because this new version uses the "my documents" folder for the settings now, and all these Windows Vista/winodws 7 virtual store folder issues go away. Microsoft is migrating all the appplications to use "My documents" folder now.
evo4mad
May 5, 2015 06:22 PM
hkumar
11
Sep 9, 2013 07:55 PM
ivan308
Feb 4, 2013 08:35 PM
charlie.tunah
Jul 13, 2010 02:24 PM
nj1266
125
Jan 12, 2010 07:37 AM
