EVOScan problems
Old May 31, 2010 | 11:24 AM
brocksdad's Avatar
EVOScan problems
I am having some problems getting EVOScan to work. I have a 2010 EVO X, ECU ID 55570005, EVOScan 2.6.
The problem I'm running into is getting the logger to display the correct values. When mode 23 is enabled, I am showing a knock sum of 64, 0 RPM, 68% TPS, 88% accel position, -25 STFT, 11.xx LTFT idle, 11.xx LTFT cruise....
When I have the standard logger enabled, I show 100% TPS, RPM is accurate, -2 - 2% STFT, 5.xx LTFT.
Has anybody else had these issues? If so, what fixed them? I am selecting mode 23 in the drop down menu. The ROM has been patched and all the values have been changed accordingly.
Thank you for your help.
Old May 31, 2010 | 12:04 PM
Golden's Avatar
EvoScan 2.6 wasn't set up for a 2010 X.
Past this into your data.xml and then select "Mode23 2010 US EVOX RA" for logging.
Code:
    <ecu name="Mode23 2010 US EVOX RA">
      <Mode2 name="Mode2" type="Data List Items">
        <DataListItem DataLog="Y" Color="" Display="RPM" LogReference="RPM" RequestID="23808763" Eval="31.25*x" Unit="rpm" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="8000" ChartMin="0" ChartMax="8000" ScalingFactor="0.1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="Y" Color="" Display="Load" LogReference="Load" RequestID="23808784" Eval="x*10/32" Unit="load" MetricEval="" MetricUnit="" ResponseBytes="2" GaugeMin="0" GaugeMax="300" ChartMin="0" ChartMax="300" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="Y" Color="" Display="TimingAdv" LogReference="TimingAdv" RequestID="23808A1F" Eval="x-20" Unit="deg" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="-10" GaugeMax="50" ChartMin="-10" ChartMax="50" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="Y" Color="#4b0000" Display="PSIG" LogReference="PSIG" RequestID="2380872E" Eval="(x/4*0.19347)-14.5" Unit="PSIG" MetricEval="" MetricUnit="" ResponseBytes="2" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="Y" Color="" Display="Knock Sum" LogReference="KnockSum" RequestID="23808A63" Eval="x" Unit="count" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="20" ChartMin="0" ChartMax="20" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="Y" Color="#90ff00" Display="External Wideband A/F Ratio" LogReference="AFR" RequestID="WDB" Eval="x" Unit="a/f ratio" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="20" ChartMin="0" ChartMax="20" ScalingFactor="10" Notes="Plug in your serial port from your wideband oxygen sensor if you have one." Priority="1" Visible="False" />
        <DataListItem DataLog="Y" Color="" Display="TPS" LogReference="TPS" RequestID="2380870D" Eval="x*100/255" Unit="%" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="100" ChartMin="0" ChartMax="100" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="Manifold Air Temp" LogReference="MAT" RequestID="2380867A" Eval="1.8*x-40" Unit="Deg F" MetricEval="x-40" MetricUnit="Deg C" ResponseBytes="2" GaugeMin="-10" GaugeMax="200" ChartMin="-10" ChartMax="200" ScalingFactor="1" Notes="" Priority="3" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="Coolant Temp" LogReference="ECT" RequestID="23808653" Eval="1.8*x-40" Unit="Deg F" MetricEval="x-40" MetricUnit="Deg C" ResponseBytes="1" GaugeMin="-10" GaugeMax="130" ChartMin="-10" ChartMax="130" ScalingFactor="1" Notes="Engine Coolant Temperature" Priority="3" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="Intake Air Temp" LogReference="IAT" RequestID="2380866D" Eval="1.8*x-40" Unit="Deg F" MetricEval="x-40" MetricUnit="Deg C" ResponseBytes="1" GaugeMin="-10" GaugeMax="130" ChartMin="-10" ChartMax="130" ScalingFactor="1" Notes="Intake Air Temperature" Priority="3" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="Speed" LogReference="Speed" RequestID="238087FF" Eval="x*1.243" Unit="mph" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="250" ChartMin="0" ChartMax="260" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="STFT" LogReference="STFT" RequestID="238088b0" Eval="(0.1953125*x)-25" Unit="%" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="LTFT idle" LogReference="IdleLTFT" RequestID="23804573" Eval="(0.1953125*x)-25" Unit="%" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="LTFT Cruise" LogReference="CruiseLTFT" RequestID="23804575" Eval="(0.1953125*x)-25" Unit="%" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="LTFT In Use" LogReference="CurrentLTFT" RequestID="238088C1" Eval="(0.1953125*x)-25" Unit="%" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="IPW" LogReference="IPW" RequestID="2380AA88" Eval="x/1000" Unit="ms" MetricEval="" MetricUnit="" ResponseBytes="2" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="Active WGDC" LogReference="ActiveWGDC" RequestID="23808b6b" Eval="x/2" Unit="unit" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="WGCD Correction" LogReference="WGDC_Correction" RequestID="23808b69" Eval="x/2-64" Unit="unit" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="Front Oxygen Sensor" LogReference="FrontO2" RequestID="2380867d" Eval="0.01952*x" Unit="V" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="Knock Voltage" LogReference="KnockVolt" RequestID="2380872b" Eval="0.01952*x" Unit="V" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="MAT" LogReference="MAT2" RequestID="23808672" Eval="1.8*x-40" Unit="Deg F" MetricEval="x - 40" MetricUnit="Deg C" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="Air/Fuel Ratio (Map)" LogReference="AFRMAP" RequestID="2380890d" Eval="(14.7*128)/x" Unit="AFR" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="Corrected Timing Advance" LogReference="Corr_TimingAdv" RequestID="238089ff" Eval="x-20" Unit="degrees" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="Rear O2" LogReference="O2Sensor2" RequestID="23808681" Eval="0.01952*x" Unit="V" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="WGDC MUT" LogReference="WGDC_MUT" RequestID="23808b6d" Eval="x/2" Unit="%" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="Load Error" LogReference="LoadError" RequestID="2380870f" Eval="0.15625*x-20" Unit="load" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="WGDC Correction MUT" LogReference="WGDCCorr" RequestID="23808783" Eval="0.5*x-64" Unit="unit" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
      </Mode2>
    </ecu>
Old May 31, 2010 | 12:31 PM
brocksdad's Avatar
That didn't work either. I was idling at 187.5 rpm and knock sum was over 200.
Old May 31, 2010 | 02:54 PM
Golden's Avatar
Then something else is wrong. I have a 2010 with 55570005 ROM and those are the values I use without any problems. Maybe take a screen shot of EvoScan so we can see what you are doing wrong.
Old May 31, 2010 | 03:28 PM
E6-X's Avatar
goto evoscan.com and DL latest version which i believe it shud be v2.7.0046 and log under 2010 models.
happy logging
Old May 31, 2010 | 05:40 PM
brocksdad's Avatar
Thanks for the help. I was trying to log a friends car and he went back home out of state. I will try 2.7 and see what happens next time.
What should the baud rate be set to?
Old Jun 1, 2010 | 01:10 PM
marinos's Avatar
hi i have a mitsu lancer 1.8cc 09 and i cant read my ecu with ecuflash when i press read from ecu this apears http://img34.imageshack.us/f/23413582.jpg i select 2006+mitsubishi can vehicles it loads and thi apears after compliting http://img294.imageshack.us/f/39504222.jpg what should i do? please help
Old Jun 1, 2010 | 02:56 PM
Golden's Avatar
You read your ROM correctly. You just don't have definition files for it.
You can still save that ROM to your computer and then see if anyone has a definition xml file for it.
Old Jun 2, 2010 | 06:19 AM
marinos's Avatar
where can i find it? i would pay to make it work so i could disable DTS
Old Jun 2, 2010 | 08:04 AM
Golden's Avatar
Read the ROM, Save it, and email it to me, I'll look. I'll PM you an address.
Old Jun 2, 2010 | 10:33 AM
marinos's Avatar
i read from ecu but when i press save as ... an error comes do you know anything about it?
Old Jun 2, 2010 | 12:48 PM
marinos's Avatar
ok you have e-mail
Old Jun 2, 2010 | 02:12 PM
Golden's Avatar
Your ROM id is 52500010.
I'm not finding much stuff out there for it.
I'm guessing this is a 2009 Lancer. But what model and what Market? EDM or something else?
Old Jun 2, 2010 | 02:42 PM
marinos's Avatar
i dont know what do you mean my car is mitsubishi lancer 1.8cc 09 model what is EDM?
Old Jun 2, 2010 | 06:47 PM
Golden's Avatar
It's the market the car is sold in. I'm not sure what all markets there are, but here are the ones I know:
USDM = USA
JDM = Japan
EDM = Europe
ADM = Australia
There is another for middle eastern, I think.
