Narrowband to wideband
Old Jun 12, 2010 | 04:40 PM
WWEvoXFTW's Avatar
I've been looking for a way to convert narrowband to wideband, does anyone have a program or an equation in which to do this?
Trying to use stock o2 on the Evo X with innovate lm2 but it's not working so I'm looking for a way to use the stock o2 sensor with evoscan.
Old Jun 12, 2010 | 04:43 PM
Bggstin's Avatar
You can't use the stock sensor as a wideband.
Old Jun 12, 2010 | 04:47 PM
WWEvoXFTW's Avatar
ive seen it before from some pro tuners, the use the front o2 with a program to convert it, and it seems to work well
Old Jun 12, 2010 | 04:56 PM
yahh's Avatar
http://www.civicforums.com/forums/7-...-use-only.html
here's a diy I found before, I know it's for a civic
Old Jun 12, 2010 | 05:47 PM
criptballer's Avatar
you're asking a sensor that sends out 0-2 volts to do what a sensor that sends out 0-5 volts can do. that's the whole point of a wideband, better resolution range.
as far as the DIY, i believe some vehicles, mainly hondas, where equiped with widebands from the factory. ours wasn't, trust me.
GL though.
Old Jun 12, 2010 | 05:58 PM
tephra's Avatar
not even that.
a narrow band only knows 2 things:
1) when its leaner than stoich
2) when its richer than stoich
it doesn't have a concept of range of leanness/richness...
just get a proper wideband
Old Jun 12, 2010 | 06:18 PM
Originally Posted by tephra
not even that.
yup, and that's directly corrolated to the fact that a narrowband goes from 0-2 volts so the car when it idles or cruises will always try to remain at 1 volt which is stoich, and variance in voltage + is leaner - is richer that's all it knows. but with a wideband it has the range of 0-5 volts, so there is more resolution to it when it goes richer or leaner.
I know we're both saying the same thing haha
Old Jun 12, 2010 | 06:20 PM
tephra's Avatar
actually most NB's operate from 0 to 1 v, with 0.45v being the "switching" voltage...
your post made it seem like 0-2v was just reduced resolution, but thats not really right at all
like 0.4v, for a 0-1v NB, is NOT equiv to 2v in 0-5v WB
Old Jun 12, 2010 | 07:06 PM
tomatoe tomato hahaha it's not my fault people don't know narrow bands have three modes, stoich, rich, or lean without any resolution in between hence the name (narrow) hahaha.
Old Jun 12, 2010 | 08:05 PM
09Ralli's Avatar
we tried the front o2 and we pulled a little over 3 volts?? i can post up the graph if needed?
Old Jun 12, 2010 | 08:28 PM
blk-majik's Avatar
Some widebands have multiple outputs and you can program the controller to simulate narrow band outputs on one (or more) of the outputs. The LC-1's let you do this. I never tried it, but if the narrow band simulation's signal was compatible with what the ECU needs to do its magic, it might save you from getting a bung welded in and just swapping the front NB for the WB, route output #2 to the NB ECU input, and output #1 to your WB gauge.
IIRC, the yellow wire in the LC-1 is the analog output #1 and is pre-programmed to simulate narrowband output, and the brown wire is analog output #2, which is used for wideband data logging. Please double check that and make sure you know what you're doing before trying this
Old Jun 13, 2010 | 04:04 AM
ZurichEvo's Avatar
So I can swap the current Narrowband sensor for the LC-1 Sensor, and set one of the outputs on this to simulate the Narrowbend sensor to the ECU? This avoids having to install a new bung? Does this confuse the ECU at all? As in different readings?
Old Jun 13, 2010 | 05:29 AM
tephra's Avatar
you can - but to be honest I have never found the LC1 reliable enough to replace the main NB sensor..
that said after I had it wired correctly etc it has become a lot better..
Old Jun 13, 2010 | 07:30 AM
veszett's Avatar
i did this a while ago when my front o2 died and mitsu in perth quoted me a RIDICULOUS replacement cost. seems to work fine. i'll prob end up just replacing the OEM narrowband when i can find one for a reasonable price. here's the thread https://www.evolutionm.net/forums/ge...da-sensor.html
Old Jun 13, 2010 | 10:40 AM
ZurichEvo's Avatar
Brilliant that will save me getting the downpipe!
