AFR calibration map
Old Jun 17, 2010 | 07:05 PM
tephra's Avatar
Smile AFR calibration map
Hi All,
I have been sitting on this for a while, I am sure others have posted information about it, or even the maps themselves.
Basically this adjusts the Fuel Map lookup by adding or subtracting a percentage.
If you are interested, look at the changes between 52680017 and 52680018
It will appear in the Misc category, eventually when it gets included in ECUFlash it will be moved to the Fuel category
52680015:
Code:
<scaling name="Percent128" units="%" toexpr="x*100/128" frexpr="x*128/100" format="%.1f" min="0" max="100" inc="2" storagetype="uint8" endian="big"/>
<table name="Calibration Fuel Map" category="Misc" address="576d3" type="3D" swapxy="true" scaling="Percent128">
	<table name="Load" address="617d6" type="X Axis" elements="41" scaling="Load"/>
	<table name="RPM" address="617aa" type="Y Axis" elements="19" scaling="RPM"/>
</table>
53040010:
Code:
<table name="Calibration Fuel Map" category="Misc" address="576d7" type="3D" swapxy="true" scaling="Percent128">
	<table name="Load" address="61812" type="X Axis" elements="41" scaling="Load"/>
	<table name="RPM" address="617e6" type="Y Axis" elements="19" scaling="RPM"/>
</table>
I doubt it will be very useful to people, but something to think about
Cheers
D.
Old Jun 17, 2010 | 07:37 PM
palmerblock's Avatar
hmmm... another way to tune fuel.....
wondering if i should try....
has anyone else?
Old Jun 17, 2010 | 07:43 PM
Clipse3GT's Avatar
I am assuming that adding to the map increases fueling in that area of the map and subtracting a percentage from a area or value decreases fueling in that area...
Secondly, I wonder what would happen if you change all values to a static value of: 102.3
Old Jun 17, 2010 | 07:57 PM
tephra's Avatar
yeah i think so... but try it
yeah im not sure why this table exists in the first place really? like what was wrong with the fuel map? :P hehe
Old Jun 17, 2010 | 08:55 PM
Clipse3GT's Avatar
Yeah that table looks really erratic in areas, except in in the full spool area it looks consistent.
I might trying setting everything to static number and see what happens...
I'll be like...
Old Jun 17, 2010 | 09:25 PM
Golden's Avatar
I'm thinking it is some sort of injector calibration. So, if they change injectors, they simple have to make a new one of these and not have to re-tune the car (and possibly re-tune 20 other configurations).
Old Jun 18, 2010 | 12:22 AM
GST Motorsports's Avatar
I have that as "injectorTime" in ms, not percent128 and the table being called "Injector Compensation Pulsewidth Adder" instead.
Not sure which one is actually correct though.
- Bryan
Old Jun 18, 2010 | 02:45 AM
tephra's Avatar
hrmm i'll have another look at the code ..
Old Jun 18, 2010 | 06:40 AM
derekste's Avatar
if it is indeed a % modifier for the fuel map... wouldn't this be a very easy way to adjust the entire fuel map based off of something like the GM flex fuel sensor? may not be the "best" way to do it, but could be better than nothing for ethanol blend changes.
Old Jun 18, 2010 | 07:06 AM
scheides's Avatar
EvoM Moderator
Whoah that is a mind***, why would they do this? Gah so I'm guessing flattening this table will make tuning a bit easier
*edit* added screenshots.
Attached Thumbnails AFR calibration map-screen-shot-2010-06-18-9.06.55-am.jpg   AFR calibration map-screen-shot-2010-06-18-9.07.05-am.jpg
Old Jun 18, 2010 | 08:35 AM
Clipse3GT's Avatar
Testing this today...
Like I said, I'll static the number 102.3 (max) in the table and see what happens...
I think this table accounts for why we need to richen the **** out of our spool up, since that table is lower in those areas... This might make tuning more linear...
Old Jun 18, 2010 | 09:20 AM
tonyboy's Avatar
hmmm... let us know the results clipse
Old Jun 18, 2010 | 09:29 AM
fostytou's Avatar
EvoM Community Team
One nice thing is that you could use this map to calibrate your fuel map to your actual AFR, but that is probably a mis-use of it
Old Jun 18, 2010 | 10:07 AM
Clipse3GT's Avatar
Well one thing I noticed...
My idle LTFT went from -0.5 to -7.1...
Cruise went a little bit negative...
I'll do a comparison latter today... vs stock map and everything set to 102.3...
Also try everything about 100-110 load one to be 102.3 and leave everthing 1000rpm and below alone...
Old Jun 18, 2010 | 10:39 AM
Here it is with pulsewidth... seems to make a little more sense:
