Bent my UICP.. can i still use it?
Old Jul 3, 2010 | 02:22 PM
bluegsr's Avatar
EDIT* LICP not UICP
when i was taking off my LICP so i can take it to go get powder coated i accidentally bent it because i forgot to take off this almost hidden bolt that holds it in place.
the dent is very minor, will it effect flow enough to where i would need to buy a new one?
if so would the UR LICP work with the Speed Circuit CAI that i just bought?
thanks in advance.
Old Jul 3, 2010 | 02:25 PM
Pal215's Avatar
Thats the stock uicp correct? Do not worry, it will not effect air flow enough to change hp numbers but it is a good time to go aftermarket
Old Jul 3, 2010 | 02:27 PM
jackygor's Avatar
Originally Posted by pal215
thats the stock uicp correct? Do not worry, it will not effect air flow enough to change hp numbers but it is a good time to go aftermarket
+1
Old Jul 3, 2010 | 03:46 PM
gizmotoy's Avatar
The stock UICP is pretty poor. You might as well upgrade it. If you're getting it powder coated, just buy a proper aftermarket piece in the color you want. Probably not much more expensive, and certainly a hell of a lot better than a bent stock one.
Old Jul 3, 2010 | 04:37 PM
bluegsr's Avatar
yeah im sure its fine but i want a new one anyway because fitment is a tad off. does anyone know if the UR LICP will work with the speed circuit CAI?
Old Jul 3, 2010 | 08:55 PM
gizmotoy's Avatar
The stock LICP is actually a pretty good part. I can see getting one for engine bay consistency, but I didn't really see any bottlenecks or problems with it. I ended up keeping mine after taking a closer look at it. The aftermarket ones are basically indistinguishable from the stock part, with the exception of finish.
Old Jul 6, 2010 | 09:45 AM
fostytou's Avatar
EvoM Community Team
Why is this in the tuning section?
That "dent" certainly looks smaller and smoother than any of the beads rolled at the ends of the pipe right in front of it.
You should probably just total the car
94AWDcoupe
Jul 14, 2023 08:38 AM
j122987
For Sale - Part Outs
39
Sep 25, 2016 10:30 PM
Codeman17
21
Apr 26, 2008 06:34 PM
EVOIX4me
Automotosports - Illinois
19
Aug 23, 2006 03:49 PM
