evoscan problem: less than 5 volts
Old Jul 7, 2010 | 04:51 AM
eddz's Avatar
anyone can help me out?
evoscan problem: less than 5 volts-evoscan.jpg
Old Jul 7, 2010 | 05:32 AM
tephra's Avatar
1) download ecuflash 1.42 and update the firmware on the cable (just plug it in and try doing a read - it will update the firmware automatically)
2) download the most recent evoscan 2.7 beta 76 or something like that
Old Jul 8, 2010 | 08:13 AM
eddz's Avatar
Thank you for your reply tephra, i reinstall both ecuflash1.42 / evoscan v2.7 0.070, but still no luck. I can only read and write on ecuflash without any problem, but when i try evoscan, it shows less than 5 volts on the cable.
Old Jul 13, 2010 | 05:21 AM
evoscan's Avatar
Silver Sponsor
can you measure how many volts is on the OBDII pin16 when plugged into the car?
Old Dec 28, 2014 | 09:02 PM
BLUE_CP9A's Avatar
I know digging up a pretty old thread but I have the exact same problem.
Was this ever solved?
Old Jan 7, 2015 | 03:53 PM
RS200Z's Avatar
I've encountered this on a friend's car previously. Apparently the root cause was his workshop tapped the power from his OBD port for his gauges or in car camera.
You may want to check that.
marco4089
Jul 9, 2016 11:02 AM
Skit
May 12, 2013 05:33 PM
puggy
Feb 2, 2011 10:13 PM
jdmsego
Jan 18, 2011 02:50 PM
jcdeng
11
Mar 10, 2010 07:48 PM
