30psi? ASC OFF? SST OFF? Fixed!
Old Jul 15, 2010 | 05:43 PM
tephra's Avatar
Lightbulb 30psi? ASC OFF? SST OFF? Fixed!
Hi Guys,
Problem: When you run the stock 3bar sensor as soon as you hit 30psi the ASC system turns off, and if you have an SST the clutches will open up.
This sucks for SST people - obviously But it is also a PITA for guys that like to have the ASC system working.
Theory: I think I have found a piece of code that basically checks the MAP sensor and as soon as it goes over 4.56volts will stop sending torque information from the Engine-ECU to the ASC-ECU and TC-SST-ECU.
Fix: Add the following XML to your .xml file and then make the change.
Please ensure the current value matches 0x00E9 BEFORE changing and flashing to the car
526800xx, 526900xx, 53040007, 53040010, 54070007, 53050009, 52370024
Code:
<table name="ASC OFF, SST OFF Fix 0x00E9 -> 0x0100" category="Misc" address="53b0a" type="1D" scaling="Hex16"/>
55590007, 55570006, 55580006, 53040013
Code:
<table name="ASC OFF, SST OFF Fix 0x00E9 -> 0x0100" category="Misc" address="53b10" type="1D" scaling="Hex16"/>
This locations probably work for other ROMID's, so please report back if they work and I will add the ROMID to the list!
Cheers
D.
Old Jul 15, 2010 | 05:47 PM
Golden's Avatar
The 55590007 looks to be the same address for the 5557000X ROMs.
I will test and get back to you. I don't really like boosting over 30...
Old Jul 15, 2010 | 05:49 PM
tephra's Avatar
ok thanks
Old Jul 15, 2010 | 05:50 PM
murlo26's Avatar
Don't be a wuss...do it!
Old Jul 15, 2010 | 06:47 PM
tephra's Avatar
updated first post with some more ROMID's...
Old Jul 15, 2010 | 07:08 PM
migs647's Avatar
thanks Tephra. This doesn't directly help me, but I appreciate that work you do!
Donation sent!!! Forgot to state reason why or who it's from... but was me ;p. I haven't even got to use tephramods yet, but I'm sure I will soon. Thanks again for all your hard work!
Old Jul 15, 2010 | 07:09 PM
tephra's Avatar
hey man thanks
Old Jul 15, 2010 | 09:27 PM
GST Motorsports's Avatar
Address looks correct for 53600009, USDM 2009 Ralliart
- Bryan
Old Jul 15, 2010 | 10:12 PM
NZEvox's Avatar
52370024 = 526800xx, 526900xx, 53040007, 53040010, 54070007, 53050009
Thanks Tephra
Old Jul 15, 2010 | 11:19 PM
bulhas's Avatar
ill check the 55590007 on the 2010 Ralliarts
Old Jul 16, 2010 | 02:01 PM
scheides's Avatar
EvoM Moderator
Husaaah! Damn it tephra and I was planning on sticking with pump gas....I swear, if you give me a reason... :P
Old Jul 16, 2010 | 03:45 PM
MarkM's Avatar
Great work, a fix at last!! Can my EcuTeK tuner apply this fix or is it ecuflash only??
Old Jul 16, 2010 | 03:48 PM
murlo26's Avatar
haha
ECUFLASH ONLY
Old Jul 16, 2010 | 04:48 PM
People still use Ecutek?
- Bryan
Old Jul 16, 2010 | 05:50 PM
HR2L's Avatar
- Bryan
