Minimum IPW Info AND Resolution patch
Old Jan 11, 2015 | 06:52 AM
  #31
chetrickerman's Avatar
Veteran: Army
I have it
58010005
Code:
<table name="Minimum IPW SHLL0" category="Fuel" address="53002" type="1D" level="2" scaling="IPW16:SHLL0"/>
<table name="Minimum IPW SHLL0 modifier #1 (0x5345 -> 0x5340)" category="Fuel" address="30bee" type="1D" level="2" scaling="Hex16"/>
<table name="Minimum IPW SHLL0 modifier #2 (0x5945 -> 0x5940)" category="Fuel" address="309e2" type="1D" level="2" scaling="Hex16"/>
<table name="Minimum IPW Code Path modifier #1 (0x7f09 -> 0x7f06)" category="Fuel" address="30bd0" type="1D" level="2" scaling="Hex16"/>
Old Jan 11, 2015 | 08:05 AM
  #32
1995gstr's Avatar
Awesome! thank you Chet now maybe I can get my 2150s running a little better.
Old Jan 11, 2015 | 09:35 AM
  #33
Veteran: Army
No worries
Old Mar 1, 2015 | 08:17 PM
  #34
simonpvs's Avatar
Does anyone have the definitions for 5691009? (Please) Just picked up some 2150's.....
Old Mar 7, 2015 | 02:37 AM
  #35
simonpvs's Avatar
Ooops, that should read 56910009. Edm and Aus models.
I can send an XML and make a PayPal donation to anyone who can help
Old Mar 7, 2015 | 07:05 AM
  #36
Veteran: Army
In case anyone else needs it
Code:
<table name="Minimum IPW SHLL5 (stock)" category="Fuel" address="53002" type="1D" scaling="IPW16:SHLL5"/>
<table name="Minimum IPW SHLL0 modifier #1 (0x5345 -> 0x5340)" category="Fuel" address="3022a" type="1D" scaling="Hex16"/>
<table name="Minimum IPW SHLL0 modifier #2 (0x5945 -> 0x5940)" category="Fuel" address="3001e" type="1D" scaling="Hex16"/>
<table name="Minimum IPW Code Path modifier #1 (0x7f09 -> 0x7f06)" category="Fuel" address="3020c" type="1D" scaling="Hex16"/>
Old Mar 9, 2015 | 08:46 PM
  #37
simonpvs's Avatar
Chet,
Thanks for the info.
I've tested that code and it wont let me do what I want. I'm not sure if it's the user or code.
If I adjust the 'new' minimum ipw (IPW SHLL0), it adjusts the "Old" IPW at the same time (they are linked) and I end up at about 36ms minimum pulse width (logged in evoscan).
Below are the settings that appear in ecuflash (screen grab) and also the xml file with the code inserted.
With the minimum ipw set at 1..024 the car will idle comfortably if started and it remains stationary, however, if driving and on decel (ie slowing down to a stop at lights) it bounces everywhere and will vary between very lean and very rich rich and stall.
If I increase it, it runs pig rich. I'm pretty sure the patch didn't work as intended. Can you please have a look at the xml for me?
File Type: xml
Old Mar 10, 2015 | 09:12 AM
  #38
Veteran: Army
Chet,
You are doing it wrong.
Old Mar 10, 2015 | 02:47 PM
  #39
simonpvs's Avatar
I figured it was user error. Sent you a donation via paypal, can you shed any light on what I'm doing wrong?
Old Nov 23, 2015 | 11:21 PM
  #40
GP148's Avatar
Does anyone have the 3 sets of addresses for the 56920008 romid handy. Have a set of 1600cc injectors I need to get going. Thanks in advance
Old Nov 29, 2015 | 06:41 PM
  #41
GP148's Avatar
Anyone???
Old Jan 13, 2016 | 06:32 PM
  #42
GP148's Avatar
Worked out the addresses of the patch by comparing hex files. Easier to do that i first thought. Anyway, for anyone out there that wants to use the patch and has the rom 56920008, here are the addresses, tested and works as it should.
table name="Minimum IPW SHLL0 modifier #1 (0x5345 -> 0x5340)" category="Fuel" address="3047a" type="1D" scaling="Hex16"/
table name="Minimum IPW SHLL0 modifier #2 (0x5945 -> 0x5940)" category="Fuel" address="3026e" type="1D" scaling="Hex16"/
table name="Minimum IPW Code Path modifier #1 (0x7f09 -> 0x7f06)" category="Fuel" address="3045c" type="1D" scaling="Hex16"/
Old Nov 22, 2016 | 09:22 AM
  #43
Mark1si's Avatar
David how about 53600010
Old Dec 3, 2017 | 08:14 AM
  #44
sleandro's Avatar
Originally Posted by richardjh
If I may help out...
Here you go Beeble - this should do the trick for 53050009:
Code:
<table name="Minimum IPW SHLL0 modifier #1 (0x5345 -> 0x5340)" category="Misc" address="2dd72" type="1D" scaling="Hex16"/>
<table name="Minimum IPW SHLL0 modifier #2 (0x5945 -> 0x5940)" category="Misc" address="2db66" type="1D" scaling="Hex16"/>
<table name="Minimum IPW Code Path modifier #1 (0x7f09 -> 0x7f06)" category="Misc" address="2dd54" type="1D" scaling="Hex16"/>
Cheers,
Rich
Rich, would you help me find the addresses for the 57140001 ROM?
thanks a lot.
Leandro
Old Jan 3, 2018 | 12:51 PM
  #45
philr8's Avatar
Any one have the tables for 56180002
Thanks
