seeking a table for 2008 Evo X GSR
Old Aug 27, 2010 | 09:38 PM
crimson red's Avatar
Hello,
In 2008, an article about ECUTEK 2008 Evo X SST maps appeared on the "LancerEvo Magazine No.37" magazine. In that article, there was a map named "Map engine load" which defines Engine Load from Manifold Pressure(Bar)(X-Axis) and RPM(Y-Axis). It was one of the scaling maps(e.g. "MAF scaling 1-3" or "MAF compensation#1-#3"), I think.
And, recently I'm guessing that in some case, maybe changing scaling table(s) needed. so I've been seeking this map by a binary editor and Excel. So far no outcomes...
Anyone knows about anything about the map, could you help me?
Old Aug 27, 2010 | 09:54 PM
GST Motorsports's Avatar
MAP Mass Air Flow Scaling 1 / 2 / 3?
What ROM ID are you looking at it for?
- Bryan
Old Aug 27, 2010 | 10:12 PM
Thank you for replying Bryan,
I'm seeking "Map engine load"(one of the table ECUTEK named).
It defines Engine Load from Manifold Pressure(Bar)(X-Axis) and RPM(Y-Axis).
It seems like below:
added(sorry forgatton):52360018(JDM, 5MT, latest)
- Bryan
Old Aug 28, 2010 | 12:37 AM
Not sure about JDM rom but for USDM 526800215-52680022 its:
<table name="MAP Mass Air Flow Scaling #1" address="60454">
<table name="MAP" address="62a2e"/>
<table name="RPM" address="62a02"/>
</table>
<table name="MAP Mass Air Flow Scaling #2" address="60178">
</table>
<table name="MAP Mass Air Flow Scaling #3" address="5fe9c">
</table>
- Bryan
Old Aug 28, 2010 | 03:17 AM
tephra's Avatar
at least they got the scaling right
Old Aug 28, 2010 | 05:46 AM
Bryan,
Thank you so much, Bryan. I got the MAP MAF scalings! There are 3 maps!
(and Golden, his evo10base_2010.xml helped me, too!)
<table name="MAP Mass Air Flow Scaling #1" address="60458">
<table name="MAP" address="62a32"/>
<table name="RPM" address="62a06"/>
</table>
<table name="MAP Mass Air Flow Scaling #2" address="6017c">
</table>
<table name="MAP Mass Air Flow Scaling #3" address="5fea0">
</table>
One quick quiestion about the x and y axes start addreses.
If the values of axes were ajusted from to the top of the elements, the RPM starts from 74 to 7500 and MAP starts from 0.06 to 2.40(like jdm below). But reffering to the usdm(52680015), it seems to starting from the second one.
Should I correct the jdm axes starting address like the usdm? What to you think about that?
jdm(52360018):
usdm(52680015):
</table>
</table>
</table>
- Bryan
Old Aug 30, 2010 | 04:44 AM
unya's Avatar
Nice Work
52360018 helpful information from you guys found a table MAP Mass Air Flow.
I added 52360018.xml.
<table name="MAP Mass Air Flow Scaling #1" address="60458" type="3D" level="1" swapxy="true" scaling="uint16">
<table name="X" address="62a32" type="X Axis" elements="19" scaling="MAP16"/>
<table name="Y" address="62a08" type="Y Axis" elements="19" scaling="RPM"/>
</table>
<table name="MAP Mass Air Flow Scaling #2" address="6017c" type="3D" level="1" swapxy="true" scaling="uint16">
</table>
<table name="MAP Mass Air Flow Scaling #3" address="5fea0" type="3D" level="1" swapxy="true" scaling="uint16">
</table>
<scaling name="MAPMAF2Load" units="units" toexpr="x*41360/65536/100" frexpr="" format="%.1f" min="0" max="400" inc="1" storagetype="uint16" endian="big"/>
<table name="Load MAP Mass Air Flow Scaling #1" address="60458" type="3D" level="1" swapxy="true" scaling="MAPMAF2Load">
</table>
<table name="Load MAP Mass Air Flow Scaling #2" address="6017c" type="3D" level="1" swapxy="true" scaling="MAPMAF2Load">
</table>
<table name="Load MAP Mass Air Flow Scaling #3" address="5fea0" type="3D" level="1" swapxy="true" scaling="MAPMAF2Load">
</table>
Then, MAP Mass AirFlow you convert a table, Load Value could be calculated.
Roughly, 10-320 so as to consider the value of the Load Value. (Load Calculate Table!?)
Load Value = CELL(MAF) * MAFMax / 65536 / 100
MAFMax(MAFSize?) : 41360 (JDM value, from MAF Compensation #3, 5Volt)
However, MAP Value is different from the ECUTeK.
You have put ECUTeK reference value, this value is published in the magazine.
Boost value, ECUTek who I think is right, invite you?
Thanks
Attached Thumbnails seeking a table for 2008 Evo X GSR-map-mass.jpg   seeking a table for 2008 Evo X GSR-1.jpg   seeking a table for 2008 Evo X GSR-2.jpg   seeking a table for 2008 Evo X GSR-3.jpg
Old Aug 30, 2010 | 04:52 AM
tephra's Avatar
Code:
<scaling name="Loadify" units="%" toexpr="(x*16/512)*10/32" frexpr="(x*32/10)*512/16" format="%.2f" min="0" max="300" inc="1" storagetype="uint16" endian="big"/>
That's the scaling for those 3 tables
They convert directly into load...
Old Aug 30, 2010 | 05:10 AM
unya's Avatar
Hi, tephra,
I used scaling(Loadify), too big Load Value,
Originally Posted by tephra
Code:
Old Aug 30, 2010 | 05:27 AM
tephra's Avatar
thats about right.
the ECU does some tricky maths to get the actual final load value, but these are as good as for the time being...
Old Aug 30, 2010 | 11:53 AM
fostytou's Avatar
EvoM Community Team
Is this the table you would adjust when dropping in an omni / orther 4 bar sensor to get AFR to match up to the fuel table with the factory MAP?
I'm guessing there are more, but this could be an easy place to start.... looks kind of like one of the features from dsmlink v2
Old Aug 30, 2010 | 04:10 PM
tephra's Avatar
yep - just the axis thou
Old Aug 30, 2010 | 04:52 PM
Yes or if you put a different turbo/MAF then stock on a 09-2010 Ralliart.
- bryan
Old Aug 30, 2010 | 04:54 PM
I just noticed the JDM table only goes to 2.40 bar. Is that correct or is your def incorrect?
- Bryan
Old Aug 30, 2010 | 05:36 PM
tephra's Avatar
i would say bad def
