GM 3 port
Old Aug 29, 2010 | 07:30 PM
wrxnevox's Avatar
i got it
thanx guys for helping me
Old Aug 29, 2010 | 07:35 PM
Rushin's Avatar
top pic is the gm
Old Aug 29, 2010 | 07:48 PM
wrxnevox's Avatar
thanx
wrxnevox's Avatar
so what is the one below
Old Aug 29, 2010 | 08:00 PM
Rushin's Avatar
It says right on it
http://grimmspeed.com/
Old Aug 29, 2010 | 08:04 PM
GST Motorsports's Avatar
It's a MAC valve like AEM / etc use.
- Bryan
Old Aug 29, 2010 | 09:04 PM
MACKLIN's Avatar
Which one is better?
Old Aug 29, 2010 | 09:24 PM
ezz-e's Avatar
Depends on the application an what level of boost you plan to use
Old Aug 29, 2010 | 09:44 PM
Evoryder's Avatar
Price:
GM > Grimm
evo guru's prefer the GM unit.
Old Aug 31, 2010 | 11:39 AM
BCOZEVO's Avatar
Originally Posted by Evoryder
Price:
GM > Grimm
I like the GrimmSpeed unit myself, it just cost more $ then the GM.
Old Sep 1, 2010 | 08:38 PM
nj1266's Avatar
Don't get the grimmspeed. It is a POS. I have tuned THREE of them and all three oscillate the boost under high load. I do not think that the MAC valve based GS can handle high boost conditions. It is just too slow to react properly. STAY AWAY.
There are ONLY two good 3-ports that work great on the EVO. 1. GM 3-port that now comes with the pnp harness. 2. The tactrix/gruppe-s/pierreburg (sp?) that comes with a pnp.
These two are EXCELLENT 3-ports. Do not waste your money on anything else.
Old Sep 1, 2010 | 09:11 PM
mrfred's Avatar
Interesting about the boost oscillations. Are these relatively high frequency oscillations, say around 20 Hz, or are they more slow oscillations occuring closer to 1 Hz?
Old Sep 2, 2010 | 01:53 PM
Kasander's Avatar
I agree with you and I saw the exact same boost oscillation.
I would say that under 22psi it work fine, at 25psi you have a little bit of oscillation but I tried 26 to 27psi and the boost is all over the place. You can really feel it in the car that it's not steady.
I've tried 4 units (Grimmspeed) and they all do the same.
I'll order a GM or a Tactrix to compare it with.
Old Sep 14, 2010 | 11:34 PM
nj1266's Avatar
I did not log the frequency when it happens. It happens at the onset of peak boost. In a 4th gear pull it will oscillate the boost from 3300 rpm all the way to 4500 rpm. After that the boost will steady out. I have tuned A LOT of GM and tactrix/Gruppe-S/Pierburg 3-ports and NONE of them behaved that way. NONE. I have had THREE of these POS behave the same way.
The first one, I blamed on the BOV flutter, but when two other cars with the same 3-port behaved the same way, I knew it was the 3-port. On one of them I swapped the 3-port to the stock solenoid and the oscillating boost went away. The owner of the car noticed it right away.
PLEASE stay far away from this 3-port.
Old Sep 14, 2010 | 11:37 PM
nj1266's Avatar
Thank you for confirming what I experienced. I thought I was going crazy at first. I am at old hand at tuning ECUboost, one of the earliest tuners to adopt it. I thought it was me at first, but as I saw three cars experience the same thing, I knew it was the 3-port.
Get the GM or tactrix, you will be much happier. I have used both of these 3-ports with great results.
