Maxing out the Evo 10 MAF?
Old Sep 24, 2010 | 11:29 AM
  #31
scheides's Avatar
EvoM Moderator
Originally Posted by GST Motorsports
Yup
- Bryan
Oh sweet so I do have a little more room on mine then! I thought it maxed out at 4.9x.
mrfred, if you're going E85 and have any plans to keep modding the car I'd go straight to a 3.5" intake. There's a local company that's making them, I don't know anyone else that has them in production right now:
http://www.mitsustyle.com/forums/sho...5&postcount=82
Rev it. I have my rev limiter set at 8150 but try and keep myself from hitting it, but the car just waaaaants to reeeevvvvv! I have half a mind to do cams/springs/drop-is just to see how much powerband this car really has, even on pump gas.
Old Sep 24, 2010 | 11:37 AM
  #32
GST Motorsports's Avatar
That intake looks just like the AMS.. but 3.5"?
- Bryan
Old Sep 24, 2010 | 11:40 AM
  #33
murlo26's Avatar
- Bryan
Weird, lol
Old Sep 24, 2010 | 11:47 AM
  #34
mrfred's Avatar
Yah, he'll probably go straight to a 3.5" MAF. It does love to rev. Power just climbs and climbs. I've got the rev limit set 8250 rpm, and he's got ARP rod bolts and 10,500 rpm springs on the cams. The car made 450 whp DJ last night on 92 oct. Having an issue with consistent knock starting at about 7750 rpm that's holding it back a little. Plus WA 92 octane sucks. I don't think its much better than CA 91 octane. Hoping he'll give E85 a try, but he's worried that the extra power is going to kill the motor.
Old Sep 24, 2010 | 12:06 PM
  #35
mlomker's Avatar
Not quite, they moved the BOV pipe back. Murlo and I had custom versions done (call them prototypes) that are knock-offs since we already had the AMS.
Old Sep 24, 2010 | 12:11 PM
  #36
blk-majik's Avatar
AMS also makes a 3.5" intake now as well. It comes with their new turbo kit. Otherwise its laid out identically to their old 3" one... the 3" CAI actually fits it with a neck-down coupler
Old Sep 24, 2010 | 12:48 PM
  #37
scheides's Avatar
EvoM Moderator
Mine does the same thing I thought it was right when the MAF was hitting 4.9v (and that it was maxed there) but its not consistent. These cars are very sensitive above 7000 it seems.
Old Sep 24, 2010 | 12:54 PM
  #38
If you look at the knock tables you'll see why.
- Bryan
Old Sep 24, 2010 | 12:55 PM
  #39
mrfred's Avatar
Good to know he's not the only one. Thanks as usual!
Old Sep 24, 2010 | 12:58 PM
  #40
mrfred's Avatar
- Bryan
Damn! Very tempting to pull back those adders at 7000 rpm+!
Old Sep 24, 2010 | 01:02 PM
  #41
murlo26's Avatar
We pulled them back on my car...we kept running into phantom knock that my tuner couldn't hear on the det cans. So he adjusted these and bam picked up another 20whp on the ole DD dyno.
People have asked if that was why my motor blew and I did ask my tuner right away and he said no because it was still pulling timing on the dyno after he adjusted them and there weren't signs of detonation at all in the block.
Old Sep 24, 2010 | 01:28 PM
  #42
scheides's Avatar
EvoM Moderator
Hrm, bryan any idea what would be considered safe to pull those back to, for experimental or long-term use?
side note: my tables don't look anything like that...I'll have to find the xml for those ones
Old Sep 24, 2010 | 01:35 PM
  #43
murlo26's Avatar
Shane probably modified yours similarly to mine.
Old Sep 24, 2010 | 01:39 PM
  #44
scheides's Avatar
EvoM Moderator
Actually, I'm not finding the XML for the 08's, only the '10:
https://www.evolutionm.net/forums/8375998-post3.html
Anyone have a link to the xml for the 08 rom?
Old Sep 24, 2010 | 01:40 PM
  #45
haha I'm not giving any knock table advice.
What rom do you need the XML for?
- Bryan
