"Problem" in 1st gear - SST
Old Feb 22, 2011 | 06:48 PM
hotshot1's Avatar
ok thanks. how much boost are you running in 3rd gear? i am at 23 now but i will be getting tuned higher soon
Old Feb 22, 2011 | 08:31 PM
RazorLab's Avatar
25psi straight till 7600 rpm in all gears except 1st and 2nd
Old Feb 23, 2011 | 12:38 AM
gunzo's Avatar
2nd has a higher limit .. you can run up to 23psi depending on turbo
The limit is due to weakness in the 1st and 2nd gear rather than a limit with the clamp pressure
Old Feb 23, 2011 | 10:17 AM
RazorLab's Avatar
Not on the RA.
Old Feb 23, 2011 | 08:38 PM
gunzo's Avatar
Not on the RA.
Same gearbox SAME software
You only have 1 thing different
Old Feb 23, 2011 | 09:25 PM
RazorLab's Avatar
1 thing different being what? S-Sport mode?
Here is what I have found:
From my logging:
The clutch pressures are *lower* between Evo SST and RA SST for the same mode and same engine loads. The RA being lower between the two.
The 1st and 2nd gear "sticking in gear" problem happens at a *lower* boost level in the RA then the Evo.
The RA does not have the 1st gear throttle close limit like the Evo does.
Those are some of the different things I have found.
I would love to hear your thoughts on those. I'm not challenging you whatsoever, just curious.
Old Feb 24, 2011 | 06:23 AM
tephra's Avatar
I would find it odd that the engine ECU controls the SST's capabilities (in terms of allowing SSPORT)
I would be HAPPY if it did thou...
Old Feb 24, 2011 | 09:04 AM
gunzo's Avatar
From my logging:
clutch pressure is a function of demand .. *shrug*
Both have almost similiar software
torque is a function of boost .. 'lower' <> same / similiar torque .. so the difference you see could be from that ..
1st gear throttle close is a ECU thing .. not a SST thing .. yes .. the RA doesn't have the limiter in place .. don't ask me why ..
You're better at finding these things than me ..
But yes .. in this case you're right .. SSport is not controlled by ECU ..
Old Feb 24, 2011 | 04:05 PM
RazorLab's Avatar
Wait, wut? Which is it?
Yes I know these things, what I am saying is that for the same load, on both RA and MR, the MR runs higher clamping pressure.
razorlab
Sep 14, 2019 11:08 AM
HunterSwift
Mitsubishi TC-SST Discussion
49
Apr 25, 2014 08:30 PM
St1g
16
Feb 15, 2010 09:01 AM
TK40
Oct 26, 2009 09:13 AM
dklau33
39
Nov 26, 2007 05:20 PM
