Help!!!! My X would go into limp mode!!!
I have a 2010 evo x. I have the Q300 CB exhaust, AEM drop in cone filter and Tune.
The problem: when I'm driving in like a normal person, just when here the BOV go off. My ASC light came on and I'm in limp mode. No throttle response!
People are telling me the air/ fuel mixture are not right. I'm letting to much air in cause I didn't change intake pipes. So I need HELP!
Did you add the BOV after you got tuned originally? Most aftermarket BOVs will cause you to boost higher. I suspect you are hitting 30psi and going into limp mode because of it.
