Confused Newbie / Need help regarding Wideband installation
Old Dec 24, 2010 | 01:59 AM
eboru-shon_x's Avatar
Question Confused Newbie / Need help regarding Wideband installation
Hello guys, I own a 2011 GSR, purchased a few bolt-ons and after being advised by many members here to purchase a wideband, I pulled the trigger on the expensive sucker (AEM UEGO).
Anyhow, so from what I understand (for whatever reason) Mitsubishi decided to package our cars with a narrowband AFR sensor. Therefore, in order to better monitor how our AFR is doing, we need a wideband AFR sensor. I get that.
But if our ECU is configured to read NB only, then how do you make it understand WB? Mind you, I do not own ECUFlash or AP, any of those reflashing programs. I've read on some threads that you could effectively disable the narrowband sensor, but if there is no AFR sensor being seen by the ECU, then I'm pretty sure that car will not run.
Please help!
Old Dec 24, 2010 | 06:46 AM
Clipse3GT's Avatar
The wideband is a standalone sensor. It does not need to be plugged into the ECU. All you need is a extra bung pre-cat.
Old Dec 24, 2010 | 07:04 AM
cbr1000's Avatar
Please help!
hey, I'm interested in how your install goes.... can you post up some pics/details as you go along?
I know I can search, but following someone's install is more fun
Old Dec 25, 2010 | 09:30 AM
yorT's Avatar
My first time doing WB install and I followed this thread:
https://www.evolutionm.net/forums/ev...nsor-bung.html
Worked out great. As far as running the cable to the cabin I can post pics of my cable route if need be. There is actually pics of different cables routing on this forum.
Old Dec 25, 2010 | 11:06 AM
fostytou's Avatar
EvoM Community Team
The sensor you remove/disable is the secondary sensor that is only checking catalytic efficiency.
Some wideband sensors can simulate the input of the narrowband sensor to the factory ECU if you want it to replace the primary sensor also... but this often works with less than ideal results. Zeitronix and the LC-1 seem to do OK with this though.
mrfred
Sep 14, 2022 07:08 PM
Femi
AEM EMS
23
Apr 5, 2016 11:38 AM
Dr. Jekyll
Apr 1, 2016 08:42 AM
mpboost
Mar 14, 2010 06:37 AM
jeemybo
Lancer Engine Management / Tuning Forums
17
Aug 24, 2006 08:21 AM
