logcfg.txt for logging onto microSD for ROM ID 53050009
Hey guys!
I got my OP 2.0 cable and I'm learning quickly, already got mode23 enabled, did my first log, compared my commercial tune to a base map and community tunes.
The one thing that I don't quite get yet is the logging onto microSD...
I tried it with the attached file that I found and edited a bit but I don't think I have it all figured out quite yet.
I'm on an EDM X MR with ROM ID: 53050009
Could you kindly take a look and see if you can spot any obvious mistakes?
PS: I'm trying to log when I turn on the cruise light...
PPS: Bonus question: How much bar/psi is safe with the SST? Not that much, right?
Thanks in advance guys, some GREAT resources on here, tuning bibles, tuning VIDEOS even, love it!!! My next step will most likely be getting a LC-1 if I can remotely justify it to myself...
WTF??? That can't be good? Forget the SST, isn't that even too much for the engine itself? Without forged internals I mean???
Thanks a lot for the help! You actually helped me in the past without knowing it...
(the def website...)
I was running 27 for almost a year on stock internals. Not 1 issue.
130 times 1.5 is 195!?!?
Either that or I don't understand it yet...
Anyway, thanks a lot, right now I'm learning many new things every day. That was an important one! Just found out that I must be boosting about 24psi, rather than the 22psi I thought I was... (bought the car tuned and used, don't have a boost-gauge)
You mean 130 BTEL and 215 BCLO???
BTEL + BCLO = Target Load
85% wgdc attains a certain pressure (which factors into load). The feedback loop looks at the attained load and says "is the car at/above/below my desired load (bclo+btel)?" It takes the answer and applies correction to the wgdc.
Please see the numerous tuning guides for this... there are quite a few in the CT9A section and I'm sure Merlin's guide has a decent section on it.
