i can not read a evo X. Help
Old Jan 30, 2011 | 09:57 AM
raulhp's Avatar
last weekend i tryed to read my friend's new evo X. i take my 2.0 tactrix cable, my laptop (used to reflash another evo 8 and 9) and the ecuflash version 1.4
I have never read an evoX before. And I did the same as other times...Plug the tactrix cable (did not find the small flash connector), open ecu flash, do the reading process, select the mitsu can vehicles, read button, ignition and OK
The ecuflash try to read, do 3 attempts and then says can not read.
Then i tryed to log the car with evoscan version 2.7, select all the options for EvoX, push the start datalogger and conect..but can not read anything, because is like the conection goes and comes, the connection screen is flickering between green and yellow
Can anyone tell me if i'm doing something wrong?
has the EvoX wideband like the Subaru GRB to log it for tune?
Old Jan 31, 2011 | 06:19 AM
tephra's Avatar
is a pre tuned vehicle? you might need to bench it.
no wideband for the Evo X Gotta install your own...
Old Jan 31, 2011 | 06:51 AM
fostytou's Avatar
EvoM Community Team
For logging make sure you have evo X ecu selected and *not* mode23 (unless you have enabled it).
As tephra said you will probably need to bench if you can't connect to the car's ECU, but you can always try updating your version of ecuflash to the beta first.
Old Feb 1, 2011 | 01:20 AM
raulhp's Avatar
thanks to both
The car is new, never tuned before. it is a SST version with all the extras. My friend only wants get tuned the fuel and timing for more boost...
can anyone tell me what is "bench"? and what is the mode 23? i read a lot of it about how activated but i dont know what is exactly
thanks
Old Feb 1, 2011 | 02:12 AM
tephra's Avatar
which ver of ecuflash are you using?
1.42 is the most recent stable to support evox
Old Feb 1, 2011 | 08:24 AM
fostytou's Avatar
EvoM Community Team
Are you sure it is a standard SE and not a special FQ model or anything? I remember reading that all of the FQ roms were locked from the factory.
Also, just to clarify the problem that you are having, can you please post the log from when you try to read it?
Old Feb 1, 2011 | 12:55 PM
raulhp's Avatar
Well
today i tryed again...I can log with evoscan 2.7
Then i upgrade to the ecuflash beta version...and i tryed again, but with the same result
The car is a Evo X 2009-2010 SST MR...i think EDM version, but i can not confirm it.
THe log is something like "no request know code" is like the ecuflash does not know the evo X code
perhaps the ecu is locked because this is the most special (and expensive) version in Spain. This car has all the extras from factory, including BBS forged wheels
Old Feb 2, 2011 | 08:23 AM
fostytou's Avatar
EvoM Community Team
Well, you didn't post the log, but with the error you are getting I'd bench it if you want to tune it. You won't be able to see / recover the tune on it, but at least you'll be able to flash it.
Obviously I don't take responsibility if something goes wrong since we don't know much about the ECU you are trying to get into.
Old Feb 2, 2011 | 09:23 AM
raulhp's Avatar
yes, i think the same...one question. If i buy a used Open Evox ecu, and get unused the inmovilizer (i dont know if it is possible on evoX) would it works?
Old Feb 2, 2011 | 11:05 AM
fostytou's Avatar
EvoM Community Team
That was pretty broken English, but I think you are asking if you can buy a used ECU to work on the car? I assume if you know the correct ROM for the car you should be fine to buy one from a similar market... the dealer will have to program your immobilizer since it is now stored in a separate module.
Old Feb 2, 2011 | 04:26 PM
tephra's Avatar
nah you cant get another ECU... not unless you get the dealer to reinstate it.
what ver of ecuflash?
Old Feb 3, 2011 | 02:05 AM
raulhp's Avatar
Sorry for my bad english. I promise you improve it. I will be in LA for 2 months in a English school (5 days per week, 4 hours per day)
Right now i have installed the 1.43 ecuflash version (beta)
Old Feb 3, 2011 | 03:35 AM
tephra's Avatar
hrmmm..... it should work..
my advice would be to bench the ECU (google for ECU Bench process or something like that)
get the ROM and send it to me for a comparison against a known stock ROM...
then we can find out if the ROM/ECU is blocking you, or if its a laptop/op20 issue...
Old Feb 3, 2011 | 07:41 AM
fostytou's Avatar
EvoM Community Team
Ohhh... you can get a guaranteed read on the bench too? Cool!
Old Feb 3, 2011 | 10:26 AM
raulhp's Avatar
Tephra, i have read your post about bench the ecu
https://www.evolutionm.net/forums/ev...h-process.html
The log on the ecuflash when i try to read is
[23:15:44.000] sending init sequence 1 (0001)
[23:15:47.218] sending init sequence 1 (0003)
[23:15:50.437] sending init sequence 1 (FFFF)
[23:15:53.140] no response to any known code
[23:15:53.140] interface close
