new X owner from Cyprus, need guidance
we don't have widely used and respected tuning companies here like you do in the States, so i'm trying to see what's the best mods/tuning i can do through the dealership. they said they will take care of simple things like air filter, CAI and exhaust changes. lowering as well.
but i need to know exactly what i want, before going in.
i use my X as a daily driver (i've had it for less than 5 weeks and already did close to 2000 miles in it), so i don't want it to get too noisy. it'd be good to see a noticeable improvement in terms of performance though. it's a '09 GSR, not a '08, but i think the stock tuning is the same
i've read a lot of threads in here and have some ideas, but i'm just curious as to what you guys would do if you had to rely on the dealership for mods. money could be an issue, but i think i can get them down to non-dealership prices (or close)
Do you have a specific power goal in mind?
Also, it is worth mentioning that you can probably install most bolt-ons easily by yourself (save $$).
Furthermore, several of the American tuning shops do "e-mail tunes" where they give you a file, and you in return send them data logs, and they tweak it from there. To do this, you'll need to spend $200 USD on a Tactrix cable... but it is worth it!
not that much really (around 40whp), i just want better air flow to the engine and an effective (but relatively quiet) exhaust
1. i could give it a try, but it'd be a risk
2. it'd likely cause me warranty problems, even though i know that technically they can't do that for simple bolt-ons
seriously?! didn't know that! i'll look into this after the bolt-ons then (and if i'm prepared to void the warranty, i guess), thanks
so, any specific suggestions for filter, CAI and dual exhaust (for the time being)?
still debating whether i should lower it before a few more of my town's roads are fixed (it'll take at least 12-18 more months, according to the authorities)
I'd recommend *not* going to the dealer for simple bolt-ons... but if you feel completely incapable of working on your car, there's probably a local shop that will charge less to turn 5 bolts and 4 screws.
Get an intake, upper intercooler pipe, and a flash (or AP).... that should take care of your power. If you drive quite a bit and are looking for comfort I'd recommend against changing the suspension.... the X is pretty comfortable while maintaining good handling from the factory.
they specifically told me NOT to take it to an outsider for bolt-ons
maybe they don't have the right to do that, but they're the ONLY Mitsu dealers on the island and i don't wanna have to fight them over the warranty being voided or something. i mean they're gonna notice the mods once i take it in for its first service
so i should stick with the oem exhaust then? and keep the oem air filter?
thanks for the help
thanks for the help
thanks for the help
thanks for the help
So far my only problems have been with my interior, so none of my modifications really have a bearing on that. I wouldn't pay the dealership to do any other work, and don't expect any warranty related mechanical problems after a few thousand miles... so take that as you will. They have to prove a modification caused the failure, but you might still have a thorn in your side if they want to be real jerks about it.
I can see them saying "yeah, we installed it... but we're still voiding your warranty because of it". I'd make sure to get whatever agreement in writing if you do go through them.
Japistani
43
Mar 23, 2011 01:35 PM
