Problem on Read ECU
Old Mar 23, 2011 | 04:47 AM
waskarn's Avatar
Problem on Read ECU
Car is EVOX 2008 Manual. Japan spec
I will read ECU by ECU Flash then ECU failed
Please help me analize it.
Thank you
[14:39:42.385] EcuFlash Version 1.43.3000
[14:39:42.385] OS Version Windows Vista
[14:39:42.385] Qt Version 4.6.2
[14:39:42.400] 59 memory models read.
[14:39:42.806] scanning for metadata models in C:/Program Files/OpenECU/EcuFlash/rommetadata/mitsubishi/EVOX
[14:39:43.492] 25 ROM metadata models scanned.
[14:39:43.492] checksum module "subarudbw" loaded.
[14:39:43.492] checksum module "mitsucan" loaded.
[14:39:43.492] checksum module "mitsuh8" loaded.
[14:39:43.492] patch module "Subaru CAN Enhanced RAM Parameter Logging" loaded.
[14:39:43.492] patch module "Mitsu CAN RAM Parameter Logging" loaded.
[14:39:43.492] flashing tool "wrx02" loaded.
[14:39:43.492] flashing tool "wrx04" loaded.
[14:39:43.492] flashing tool "sti04" loaded.
[14:39:43.492] flashing tool "sti05" loaded.
[14:39:43.492] flashing tool "mitsukernel" loaded.
[14:39:43.492] flashing tool "mitsukernelocp" loaded.
[14:39:43.492] flashing tool "mitsubootloader" loaded.
[14:39:43.492] flashing tool "shbootmode" loaded.
[14:39:43.523] flashing tool "shaudmode" loaded.
[14:39:43.523] flashing tool "subarucan" loaded.
[14:39:43.523] flashing tool "mitsucan" loaded.
[14:40:19.481] deleting current metadata
[14:40:19.481] scanning for metadata models in C:/Program Files/OpenECU/EcuFlash/rommetadata
[14:40:50.494] 496 ROM metadata models scanned.
[14:42:07.673] J2534 API Version: 04.04
[14:42:07.673] J2534 DLL Version: 1.00.2997 (DEBUG) Mar 31 2010 18:34:34
[14:42:07.673] Device Firmware Version: 1.11.3137
[14:42:09.263] -- loading kernel --
[14:42:09.263] -- connecting to kernel --
[14:42:09.263] kernel get version
[14:42:10.091] interface close
[14:42:10.103] interface close
[14:42:34.034] J2534 API Version: 04.04
[14:42:34.034] J2534 DLL Version: 1.00.2997 (DEBUG) Mar 31 2010 18:34:34
[14:42:34.034] Device Firmware Version: 1.11.3137
[14:42:35.269] -- loading kernel --
[14:42:35.269] -- connecting to kernel --
[14:42:35.269] kernel get version
[14:42:35.615] ECU HW part number : 1860B221
[14:42:35.640] ECU SW part number : 1860B18101
[14:42:35.660] VIN : CZ4A-0100360
[14:42:35.695] -- unlocking ECU --
[14:42:35.695] starting session...
[14:42:35.974] requesting seed...
[14:42:35.983] sending key...
[14:42:36.805] interface close
[14:42:36.817] interface close
Old Mar 25, 2011 | 08:23 PM
waskarn's Avatar
After read ECU fan on but not start the car.
ECU flash clicked on recovery mode
Old Mar 26, 2011 | 07:04 AM
Hiboost's Avatar
I had a similar issue when trying to flash a friend's car. Likely your ECU is considered bricked and the last time it was flashed it likely had an error and left the fan running. At this point your best option is to "bench" the ECU using these instructions to recover it back to a working state. If you aren't handy around electronics then consider sending it to a shop that can recover it for you using this method:
https://www.evolutionm.net/forums/ev...-pictures.html
Be sure to follow the first couple of steps, also finding the 0.1" female connectors might be challenging in that the Tactrix cable has wider pins than the ECU. Your best bet is to find connectors that can spread open slightly with some tension as you push them in farther.
Good luck!
MsEvoVIII
Jul 26, 2014 11:14 PM
XTR Performance
Lancer Ralliart Vendor Classifieds
211
May 27, 2014 05:33 PM
XTR Performance
EvoX 'For Sale' Suspension / Brakes / Handling
22
Jul 11, 2012 10:09 AM
EvoX6436
Jan 30, 2010 07:52 AM
waskarn
Lancer Engine Management / Tuning Forums
Jan 9, 2010 01:42 PM
