Tuner can't clear P0140 via ECU
Who pays to fix CEL after tune? Tuner or Tunee?
Let's say you have no codes before the tune and the car has less than 3K miles. You get a tune and the tune causes the CEL to come on. Tuner and Tunee agree the light came on due to tune.
1- Should the tuner provide their services for free to fix the code?
2- Should tuner only be responsible for labor and not parts since this is a hack?
3- Should the tuner not be responsible for anything? This is the tunee problem.
It is the right section. P0140 is thrown from having a test pipe / rear 02 sensor complaining that the cats aren't working right.
He is referring to getting it turned off in the ECU.
You can shut it off without fail on all USDM models. '08 through '10. I'm guessing this tuner doesn't know exactly how to do it right.
If your tuner doesnt fix it for free, walk out and go get a new tuner. Thats what i would do, they just tuned your car for $4xx and you have a check engine light on? No it doesnt work that way.
Just playing with my own car and looking around at other roms from 2011 and 2010 and do not seem to be able to disable the p0140. Is this the case for 2010 and newer or is there something I am missing?
Thanks
-Em
Thanks
-Em
