Evo X Real CAN Packets
Old Apr 24, 2011 | 09:50 PM
hpd_wally's Avatar
This is just a start, but I have logging the real can traffic on the x's bus, and have started to find some matching channels, this is for the 55571006, but sure the scheme is close for the 2008's as well.
I have a list of about 10 more packets that I have found, just not on this local comp right now, I will update with more that I find
Code:
id	sb	len	type	scale	offset	name
0x308	1	2	u16	1	0	RPM
0x312	2	2	u16			???
0x312	4	2	u16			???
0x415	0	0	u8			ac swtich (0x10)
0x608	0	1	u8			ECT
0x608	6	2	u16			???
0x210	0	2	u16	0.00114	13.37	TPS_AN
0x210	2	2	u16			???
0x212	0	2	u16	1	0	IDLE_RPM_TARGET
0x212	2	2	u16			???
0x356	4	2	u16			???
0x380	1	1	u8			Brake/Clutch???
TX Packets from ECU
Code:
Can ID	Hex ID	In rom TX	Slot	DLC	Ret Func	TX Store
100	400	81d1e	18	4	C	811674
101	401	81d1c	17	1	C	811673
210	810	81d1a	16	8	C	81166B
212	812	81d18	15	8	C	811663
255	915	81d16	14	8	C	81165B
308	C08	81d14	13	8	C	811653
309	C09	81d12	12	7	C	81164C
312	C12	81d10	11	8	C	811644
356	D16	81d0e	10	7	C	81163D
380	E00	81d0c	9	2	C	81163B
415	1015	81d0a	8	7	C	811634
4a0	1220	81d08	7	8	C	81162C
590	1610	81d06	6	4	C	811628
608	1808	81d04	5	8	C	811620
6fa	1B3A	81d02	4	8	C	811618
6fe	1B3E	81d00	3	8	C	811610
7bc	1E3C	81cfe	2	8	C	811608
631	1831	81cfc	1	8	B	811BD4
7e8	1F28	81fca	0	8	A	811Bcc
RX Packets from rest of Car
Code:
Can ID	Hex ID	In rom Rx	DLC
110	410	82a4e	27	4
111	411	82a4c	26	8
208	808	82a4a	25	8
215	815	82a48	24	8
218	818	82a46	23	4
248	908	82a44	22	4
265	925	82a42	21	7
2f1	B31	82a40	20	7
300	C00	82a3e	19	6
315	C15	82a3c	18	5
316	C16	82a3a	17	8
318	C18	82a38	16	8
325	C25	82a36	15	6
338	C38	82a34	14	6
365	D25	82a32	13	7
408	1008	82a30	12	6
412	1012	82a2e	11	6
418	1018	82a2c	10	1
428	1028	82a2a	9	8
520	1420	82a28	8	7
591	1611	82a26	7	8
5fe	173E	82a24	6	7
6fb	1B3B	82a22	5	2
6fd	1B3D	82a20	4	3
6ff	1B3F	82a1e	3	1
7df	1F1F	82a1c	2	8
7e0	1F20	82a1a	1	0
630	1830	82a18	0	8
Old Apr 24, 2011 | 11:12 PM
dyulov's Avatar
What sort of hardware did you use for getting can traffic?
Old Apr 25, 2011 | 07:13 AM
hpd_wally's Avatar
Canusb.com. USB dongle. I had to write an app for it in qt. The c interface library is the only one that supports interrupt based message reception. If you used a managed framework (c#) you gave to poll
It's quickest to log packed binary data and open it with atlas or matlab. Your choice really. I logged tandem with the tactrix setup to help correlate the data to known measurements
Old Apr 25, 2011 | 07:23 AM
acamus's Avatar
From: Lattitude 48.38°, Longitude 17.58°, Altitude 146m = Slovakia, for common dude
Nice gadget, but for little more money you can get a better solution.
Old Apr 25, 2011 | 11:18 AM
hpd_wally's Avatar
Interesting product but I assume that it does not have a phy and cannot actually send messages on the bus and interact with anything else. The canusb device is *****en because its cost sensitive and has an API that you can integrate into lab view. Matlab c# qt vb and others. This thing has been used in much that I do at work
Old Apr 25, 2011 | 11:56 AM
RazorLab's Avatar
Can you find specific CAN ID requests for logging purposes with what you are doing? If so I have some questions for you.
Old Apr 25, 2011 | 12:16 PM
hpd_wally's Avatar
I haven't gone through code for the 9's yet, but could probably try the same method. The key is that the M32R packs the can id in a funky format for the can structure (ie 0x100 is shown in code as 0x400 from the bit rolling and shifting that the hardware nativly wants to see).
Are you going to be running any Nasa events in the next month? I should be up @ button willow in a few weeks with some guys at work. Send me your rom and xml files, and I can open it in IDA and see if they have retained some of the same can spec.
Old Apr 25, 2011 | 01:49 PM
RazorLab's Avatar
Is this reply to me?
I was actually asking for the Evo 10 / RA
The 8/9 are not CAN based.
Old Apr 26, 2011 | 06:16 AM
tephra's Avatar
if you want to sniff the CANBUS you can do it with an OP20 - Colby includes a packet sniffer - you just need to compile it.
you will need to connect directly to the bus thou and not to the OBD connector as that is proxied via ETACS...
Old Apr 26, 2011 | 06:18 AM
dyulov's Avatar
Where i can find it?
may you have any pictures?
Old Apr 26, 2011 | 06:19 AM
tephra's Avatar
C:\Program Files\OpenECU\EcuFlash\samples\canlogger
Old Apr 26, 2011 | 06:21 AM
dyulov's Avatar
Thanks a lot. What is about connection?
Old Apr 26, 2011 | 06:22 AM
tephra's Avatar
either bench the ECU.
or tap the pins/wires at the ECU in the car..
Old Apr 26, 2011 | 06:24 AM
dyulov's Avatar
Ok. I will be looking for...
Old Apr 26, 2011 | 06:30 AM
dyulov's Avatar
One more question: which version of EcuFlash has such samples? I have latest and don't see such directory. is it possible to send me source
