ATR - fuel maps
Old May 14, 2011 | 07:01 AM
xhomm02's Avatar
ATR - fuel maps
Hi, does somebody know it the maps in Access Tuner Race is on the X-axis driven by Load-Boost or Load-Timing?
Old May 14, 2011 | 10:25 AM
Kracka's Avatar
X axis = load
Load is a calculation based off a number of factors in the engine's current state of operation.
Old May 14, 2011 | 11:07 AM
xhomm02's Avatar
Originally Posted by Kracka
X axis = load
I know
ATR uses 2 loads (which you can log) - Fuel and Timing, they differ. I need to know which of them is used on the X-axis.
Old May 16, 2011 | 08:16 AM
fostytou's Avatar
EvoM Community Team
Originally Posted by xhomm02
I know
You said "Load-Boost or Load-Timing"
This may be some rocket scientry... but the load relative to fuel is most likely fuel-load.
Old May 16, 2011 | 10:04 AM
xhomm02's Avatar
Oh, my mistake :-)
But in ATR in "Target boost table" the number set for target load is named as "Load boost/fuel", but in the log the value is equal to logged parameter "Load/Timing", instead of logical "Load boost/fuel", that´s why I asked....
I know it sounds a little confusing :-)
Old May 16, 2011 | 10:21 AM
fostytou's Avatar
EvoM Community Team
Oh, my mistake :-)
Gotcha... so you are looking for what value the boost table is using as its load value. I can't specifically answer that, but if it appears that your output is closer to one than the other I would use that one.... I'm not sure if this was ever nailed down specifically.
Just remember that there are changes based on throttle/gear switchover/etc to the wgdc target before it is output.
No_Skillz
May 8, 2015 10:34 PM
stunt2
May 25, 2012 01:46 PM
W2J
May 16, 2011 03:27 PM
crimson red
Jan 7, 2010 08:30 PM
mexevo
Dec 19, 2007 11:38 AM
