MAP Based Load Calc Copying Problem
Old May 4, 2015 | 04:19 PM
No_Skillz's Avatar
I am trying to copy my current tune to TephraMOD V2 map. Everything is fine but the following tables are not taking correctly:
MAP Based Load Calc #1
MAP Based Load Calc #2
MAP Based Load Calc #3
1 and 2 will copy, but as soon as I copy over 3, the values in 1 and 2 change. Is there some sort of different algorithm? Has anyone else dealt with this?
Old May 4, 2015 | 08:48 PM
rrkpitt15's Avatar
Do you have a 2010?
Old May 6, 2015 | 10:59 AM
No_Skillz's Avatar
Nope, it's a 2011. I'm going from ROM 56890007 to 56890213 (which is Tephra's modification of 56890013 I believe).
Old May 8, 2015 | 10:34 PM
No_Skillz's Avatar
In case anyone is looking for a resolution - Tephra has helped me immensely over email and figured out this issue.
As of ECUFlash v1.44.4341, the xml definitions for 56890013 is incorrect. The address pointing to MAP Based Load Calc #2 and #3 are wrong.
MAP Based Load Calc #2 address should be 60600
MAP Based Load Calc #3 address should be 602fe
sleandro
Aug 13, 2017 07:26 AM
Whoop_ass
Sep 5, 2007 02:25 PM
kreionic
Jun 7, 2007 03:13 PM
coolguycooz
Dec 17, 2006 07:33 AM
Drifto
Oct 4, 2006 09:35 AM
