stage 2 over boost question
Old May 29, 2011 | 12:31 AM
Mazzab's Avatar
Take a look at this map for me. I have a HFC and cbe. I'm running stage 2. It says im over boosting, but i'm not getting any CEL, my fuel trim is under 8% and i'm not getting any knock. It says im at 28psi, i switched to lwg maps and it says im getting only 20psi then. my boost pill is out, i plan to put it back in and see what happens, my question is, if i'm not getting any CEL or spikes, it just seems like it spools up correctly and linearly, and its within fuel, no traction control issues, i live in PA, is this a problem?
Attached Thumbnails stage 2 over boost question-part-1.jpg   stage 2 over boost question-part-2.jpg
Old May 29, 2011 | 01:06 AM
BakaUnchi's Avatar
please email me 3rd gear log of both
2000-7500 rpm
logging AND DISPLAY ONLY these parameters
RPM
Load fuel
psi (boost)
Knock
wgdc fine
Inj duty cycle (IDC)
and throttle
Old May 29, 2011 | 10:24 PM
Mazzab's Avatar
2000-7500 rpm
RPM
Load fuel
psi (boost)
Knock
wgdc fine
and throttle
pull 1
Attached Thumbnails stage 2 over boost question-pull1p1.jpg   stage 2 over boost question-pull1p2.jpg   stage 2 over boost question-pull1p3.jpg
Old May 29, 2011 | 10:26 PM
Mazzab's Avatar
2000-7500 rpm
RPM
Load fuel
psi (boost)
Knock
wgdc fine
and throttle
pull 2
Attached Thumbnails stage 2 over boost question-pull2p1.jpg   stage 2 over boost question-pull2pt2.jpg   stage 2 over boost question-pull2pt3.jpg
Old May 29, 2011 | 10:57 PM
Mazzab's Avatar
Columns in order L to R; time, rpm, acceleration pedal pos, inj duty cycle, knock, wgdc fine, throttle, boost pressure, load boost/fuel
Old May 30, 2011 | 02:59 AM
BakaUnchi's Avatar
just email me the log files right off the ap
done even open them just send over
Old May 30, 2011 | 07:38 AM
Mazzab's Avatar
I still need your email though, PM me it?
