MIVEC - high overlap
Old Jun 13, 2011 | 08:54 AM
xhomm02's Avatar
Hello,
I would like to ask you Evo gurus here (both question concern low load/RPM, while in cruise under vacuum):
1) when EX MIVEC is much retarded (), exhaust gases are sucked back into chamber and mix with fresh air, right?
2) when IN MIVEC advanced too much, can be exhaust gases be pushed to intake manifold during exhaust stroke and sucked back while intake stroke?
Would 1) or 2) or both influence AFR readings?
Old Jun 13, 2011 | 02:14 PM
Golden's Avatar
No. AFR will only be affected if you are pushing fresh O2 air out into the exhaust.
The reason you suck exhaust air in the chamber is to not have high vacuum while cruising. The exhaust gas lacks oxygen, therefore it doesn't mess with your AFR.
Old Jun 13, 2011 | 10:50 PM
xhomm02's Avatar
Thank you,
how about no#2)? Could it help with pumping efficiency in cruise? Will not low fresh air in chamber cause need for wider throttle open?
Old Jun 14, 2011 | 09:21 AM
Golden's Avatar
You MIVEC should be configured that way already. The stock tune is pretty good in the cruise range.
Old Jun 14, 2011 | 11:57 AM
xhomm02's Avatar
thanks
moparfan
Mar 18, 2021 10:28 PM
sdhotwn
Lancer Engine Tech
28
Sep 27, 2009 08:43 AM
Geoff Raicer
34
May 21, 2009 05:29 PM
04Evo8RS
Aug 15, 2006 05:04 PM
2k4EvoVIII
68
Jan 22, 2005 03:46 AM
