Reading from TPMS
Old Aug 31, 2011 | 06:55 AM
TravisF's Avatar
Reading from TPMS
Has anyone looked into reading tire pressure from the TPMS system? Is it even possible? The sensors must read the actual pressure because a warning comes up on cold mornings if the tires are below ~30 psi.
Old Aug 31, 2011 | 07:41 AM
tephra's Avatar
I'm sure its possible..
Trouble is here in AU we don't get TPMS, so I cant go and "sniff" the CAN traffic to work out the requests the MUT3 would use to grab the info.
Old Aug 31, 2011 | 08:23 AM
Supraboy1's Avatar
The TPMS is the EVO is a lower grade sending unit that only sends a signal if the sensor does not have enough pressure on it. Next time your tire is off the car you can verify this by the part number on the sensor. The same company makes much better and even some lower grade sensors. The high grade one will read tire pressure and temp on each tire within .1 Of course we dont have the receiver to get this data in our cars.
Old Aug 31, 2011 | 08:26 AM
tephra's Avatar
really?
well I guess you learn something new everyday..
Old Aug 31, 2011 | 08:33 AM
Supraboy1's Avatar
Originally Posted by tephra
really?
Yeah I have a client that sells tires, wheels, carries all the various sensors for different cars, etc.
Old Sep 2, 2011 | 08:29 PM
TravisF's Avatar
Cool thanks for the info. I figured if it had been possible Mitsu probably would have put the readings in the center display like other cars.
Old Sep 3, 2011 | 02:58 AM
Supraboy1's Avatar
They certainly could have. I'm sure it saved them a whole 2 bucks not to... Car manufactures do some of the dumbest **** to save money...
TPMS N.G.S.
Vendor Classifieds
173
Jun 13, 2018 08:39 AM
stealthMR
Toronto Lancer Club
31
Sep 27, 2017 07:38 PM
EVLX
Nov 21, 2015 10:23 PM
edIT
For Sale - Wheels / Tires
Mar 25, 2014 04:29 PM
