custom 3" exhaust questions
Old Sep 9, 2011 | 04:03 AM
pwnstar's Avatar
i have a question my buddy is making me a full exhaust and down pipe for my evo x gsr hes very good with the dsm's and older evos but has never messed with an x he wants to know when putting the stock o2 sensors back in to the piping will thay need to be spaced so thay do not throw a code or will thay throw a code no matter what and i will just have to get the engin light flashed off? or could someone give me some info so i can buy the pipe and get this done thanks
Old Sep 9, 2011 | 06:54 AM
Noe18's Avatar
I'll say just put the in the same spot as oem should throw a code
Old Sep 9, 2011 | 08:05 AM
Kracka's Avatar
It will most likely throw a code either way, just plan to have it turned off when getting tuned.
Old Sep 9, 2011 | 11:05 AM
rps13nismo's Avatar
o2 simulator -can get one from meganracing or pep boys
http://www.meganracing.com/product_page.asp?catid=22
mechanical o2 fix... they also have a version 2. i know RRE does it for their customers
Old Sep 9, 2011 | 11:31 AM
guswaym's Avatar
those simulators are half *** just get it turned off when you get it tuned or get a accessport and turn it off yourself
Old Sep 10, 2011 | 04:38 AM
pwnstar's Avatar
ok thanks guys one last question when and if the check engin light comes on will it throw the car into limp mode? see i come from honda and when the check engin light was on it would go in to limp mode and throw more gas then needed into the engin
Old Sep 10, 2011 | 09:29 AM
Mike W's Avatar
Easiest is to turn it off in the ECU. Spacers on Xs and 4G Eclipses are very hit and miss. What works on one car does not always work on another. We sell spacers for guy that are scared of flashing or for cars that cant turn off the code in the ECU.
I cant imagine someone that has built DSM stuff would be having you ask this question though. Isn't it the same with every car on the planet? If you don't want a CEL light you have one sensor before the cat and one sensor after the cat? And if no cat you need a mechanical fix (spacer of some sort) or turn off the code in the ECU?
Mike W
Old Sep 10, 2011 | 04:38 PM
pwnstar's Avatar
yea he just said hes never done an exhaust on an x and dident know how thay would turn out he said i would probly have to turn it off thro the ecu, the thing i need to get is a Tactrix cable right? and when it throws the light will it send the car into limp mode i know hondas when the check engin comes on it goes into a limp mode and throws a load more gas in the motor, why i have no idea just wouldering if the evos did the same.
Old Oct 12, 2011 | 04:56 PM
pwnstar's Avatar
exhaust is really raspy
Old Oct 12, 2011 | 04:57 PM
pwnstar's Avatar
will a high flow cat help?
Old Oct 12, 2011 | 07:16 PM
Ladogaboy's Avatar
Will a sensor before and after a HFC still throw a code? Or is it another one of those maybes?
Old Oct 13, 2011 | 11:24 AM
fostytou's Avatar
EvoM Community Team
Its a maybe. Mine didn't for ~5 months and then came on twice in a week. Its really best to just flash the ECU.
Old Oct 13, 2011 | 12:31 PM
shawnburch's Avatar
I have had a test pipe on my RSX for years with a CEL, the car never went in limp mode.
Old Oct 13, 2011 | 11:45 PM
Ladogaboy's Avatar
You want to keep the sensors for logging, though?
Old Oct 14, 2011 | 07:37 AM
fostytou's Avatar
EvoM Community Team
Is that a question?
Logging narrowband O2 is nearly pointless... but you are only disabling the rear sensor and/or the CEL.
