Service Engine Soon Light
Okay I recently got a DownPipe, Test Pipe, a BOV, and a tune installed about a week ago.
When I left the shop when I put the car into 5th gear and got on it a little the yellow "Service Engine Soon" light flashed a few times but went away.
Then it did that again a couple days later. Well this morning that light came on and now it's staying on.
What could this problem be? Emissions monitor problem? It only did that flashing when I really got on the gas pedal. Just cruising it didn't come on.
The car only has about 7,900 miles on it and before I had that stuff installed and a tune that light never came on. The car runs just fine btw.
Update: Went to Autozone and they ran a check for me and this what it said,
Okay I just got back from Autozone and the code they gave me is, P0133
Big deal and how did this happen?
I noticed lots of black soot on my trunk that I didn't used to get since getting the Test Pipe and DownPipe installed. Could the 02 Sensor problem be causing my car to spew soot from the exhaust all over the back of my car?
the black soot is normal because of the test pipe.
you can fix it with an antifouler
also I've got the same code after putting my test pipe on. I've been driving around like that with about 2000 kms and it's fine. I will get it properly tuned and disabled soon though.
That code can/will still appear with a lot of those cats as they do not do a suffient enough job of cleaning your exhaust gases.
If you had posted one of those pics earlier, I couldn't see it on my work pc. Sorry.
