Service Engine Soon Light
Old Oct 31, 2011 | 06:01 PM
ScottSpeed21's Avatar
Originally Posted by Alpha X
Everyone keeps saying it's because of the high flow cat. P0133 is for the front O2 sensor, before the cat. If the code lights up and then goes away, that sensor might be starting to go bad...it does happen. Exactly the same thing happened to me. It would throw a 'slow response' code and go away, then it wouldn't go away and the car started to run like crap in closed loop, then it threw a 'front O2 sensor no activity' code when it finally crapped the bed. I swapped in a new front sensor and everything was good.
P0139 is the 'slow response' code for the rear sensor after the cat, that's the one you can disable.
Old Nov 1, 2011 | 06:29 PM
Alpha X's Avatar
The service engine light went away. Should I still get it checked out? And why would it just randomly go away?
Old Nov 2, 2011 | 01:13 PM
Alpha X's Avatar
No one knows why the light would randomly go away?
Old Nov 2, 2011 | 01:38 PM
I don't know...ask the light why it went away...
Trying to diagnose an electrical issue on a car can be tough. At least you know that it is the front sensor, so if it happens again you know what would have to be replaced.
Old Nov 2, 2011 | 02:47 PM
fostytou's Avatar
EvoM Community Team
For most "out of range" codes the car may detect that it has been back "in-range" for a long enough period and assume it was a batch of bad gas, high altitude, or some other unknown issue. Likely the code is still stored in the ECU, but the CEL / SES is just not displayed any longer.
Describing your problem as "when I put the car into 5th gear and got on it a little" is not really very descriptive. Is it only in 5th gear? ...when you are on the throttle 40% for 2 seconds? ...when you are WOT for 5 minutes? We aren't magicians... we need every detail possible (within reason) to help solve your problem.
Why haven't you taken the car back to the tuner yet?
Old Nov 3, 2011 | 03:24 AM
T-Pain's Avatar
My cel turned off for a day last month and came back on.
I don't know why either but it is related to your exhaust
your tuner will be able to fix it for you or switch out your test pipe
Jordan Spackman
Mitsubishi TC-SST Discussion
Jan 16, 2017 04:49 PM
BrandonIX
Dec 7, 2016 02:34 PM
Buguy
May 15, 2012 02:45 PM
AJsGenerX
May 8, 2012 05:54 AM
FireFighter2968
Lancer Troubleshooting
10
Dec 3, 2007 03:39 PM
