Sponsored by:
Sponsored by: CARiD
Issue: P0302, P0137, P0131
Old Apr 13, 2012 | 03:56 PM
AJsGenerX's Avatar
Hello All. I'm super concerned about an issue I encountered. I just got tuned yesterday by Sean Ivey and put down 362 whp and 336 wtq with all the bolt-ons you see in my signature. Last night, I hit some boost in 2nd gear and the car had a hiccup. The car was then running super rich and shot flames everywhere out the exhaust. The car's service engine soon light came on as soon as the hiccup happened (misfire). The car went into limp mode regulating boost. I swapped all the plugs today for HKS M40XL. Before I installed the plugs, I only had an error code of P0302 (cylinder 2 misfire). I erased the codes, installed the plugs and as soon as I turned on the car, the SES light came back on. Codes were P0302, P0137, P0131. Can any tuning guru help me out? I'm a bit concerned.
DTC P0137: Heated Oxygen Sensor Circuit Low Voltage [SEMSOR
DTC P0131: Heated Oxygen Sensor Circuit Low Voltage [SEMSOR
DTC P0302: Cylinder 2 Misfire Detected
Thanks,
AJ
Old Apr 13, 2012 | 04:09 PM
AJsGenerX's Avatar
Another note: The car is reading lean on the Wideband when just cruising around without boost.
Old Apr 14, 2012 | 12:15 PM
Thegame's Avatar
It sounds to me like your oxygen sensor went bad. The front one.
Old Apr 14, 2012 | 01:51 PM
AJsGenerX's Avatar
I was thinking the same thing. I did a compression test and all cylinders are consistent. When you say front oxygen sensor, do you mean pre-cat?
Old May 7, 2012 | 12:43 PM
escodotcarter's Avatar
it ended up being a bad maf.
Old May 7, 2012 | 12:47 PM
Kracka's Avatar
If you experience problems the day after a tune, go back to the tuner!
Old May 8, 2012 | 05:54 AM
deanob's Avatar
Ya was going to say the MAF after reading OP. recently dealt with this with the brother in laws STI. Ran like it was on only 3 cylinders, gave misfire codes and bad o2 / low circuit (lean).
Swapped out MAF with a known working one... boom ran butter smooth.
blowngasket
Feb 13, 2014 09:42 AM
Russ444
Lancer Engine Tech
12
Aug 9, 2011 04:42 PM
gnulooks
10
Mar 20, 2011 01:02 AM
Mortis
Jan 11, 2011 05:09 PM
gallas
Dec 9, 2010 11:53 AM
