Sponsored by:
Sponsored by: CARiD
TPMS light? Please help
Old May 8, 2012 | 08:55 AM
Jcon90's Avatar
Yesterday, I was heading to work up the freeway (bout a half hour drive) and while cruising my TPMS light went off. I hadn't ran over anything, and when I checked the pressure was fine in all my tires. The light stayed on the rest of the day. This morning before work I checked and it was magically off! Drove picked up my buddy then headed to work. About half way there it came on again, but everything seems A ok pressure wise. Has this happened to anyone? Is it somehow heating up and causing a bad reading? This hasnt happened at all until 2 days ago. Any help would be great.
Old May 8, 2012 | 08:59 AM
Wildcat Birdie's Avatar
The TPMS could potentially be faulty and not sending the proper signal. It generally is reset after the car is off for so long, and will come up after a certain duration when the car is on if it never gets a signal from the sensor
Old May 8, 2012 | 09:03 AM
Alien Visitor's Avatar
What were your pressures exactly?
Old May 8, 2012 | 09:07 AM
dek0026's Avatar
it usually comes on once you hit about 25psi and will reset after 20 minutes or 20 miles (whichever).
Old May 8, 2012 | 09:24 AM
Jcon90's Avatar
My pressure was within 29-32 when I checked. I just find it weird that it's coming on as it gets warmer ( pressure rises ) It would make more sense if it was on then turned off
stealthMR
Toronto Lancer Club
31
Sep 27, 2017 07:38 PM
tsizzle
Oct 8, 2016 12:07 AM
mar387
Mar 6, 2016 10:28 PM
mRVRsport
Outlander Sport
19
May 26, 2015 01:03 PM
russ72
Nov 3, 2014 11:11 AM
