ICS switch not working after flashing with new Rom ID
Old Dec 10, 2011 | 06:23 PM
syncmotion's Avatar
Hi Guys,
I've got this weird problem but not a major one, if any expert in this Evo community would be able to help me with thanks in advance.
Here is my problem My Evo X original rom ID was 53050006 which everything working fine, but not refine as 53610010 Ralliart ID so I was using 53610010 to tune my Evo and making reasonable hp, but for some reason the ICS switch does not work anymore. And if if I flash the rom Id 53050006 back to the car this ICS switch working again. Is there any solution for this? Please help.
Old Dec 10, 2011 | 07:36 PM
tephra's Avatar
use 53050009
Old Dec 10, 2011 | 09:33 PM
syncmotion's Avatar
I have try that all Load% tables are all over the places
Old Dec 10, 2011 | 09:38 PM
tephra's Avatar
get a proper def?
try goldenevo.com
Old Dec 10, 2011 | 10:08 PM
syncmotion's Avatar
Just download 53050009 from Goldenevo.com, same thing happen Load (%) still all over the places
Old Dec 10, 2011 | 10:24 PM
tephra's Avatar
did you remove the old def?
what table is load all over the place for?
Old Dec 10, 2011 | 10:42 PM
syncmotion's Avatar
Yes I did remove old def see attached image
Attached Thumbnails ICS switch not working after flashing with new Rom ID-capture.jpg
Old Dec 10, 2011 | 10:44 PM
tephra's Avatar
looks like the table data AND rpm axis AND load axis are fubared...
send me an email and I can give u a proper def...
myusername@gmail.com
Old Dec 10, 2011 | 10:52 PM
syncmotion's Avatar
Pm done
richardjh's Avatar
Originally Posted by syncmotion
Hi Guys,
Whoa, if I'm reading this right you mean you actually flashed a Ralliart ROM to your Evo X?
Not "used a Ralliart ROM XML to look at your X ROM in EcuFlash"... but used a 53610010 ROM image itself to reflash your ECU?
Please clarify...
Rich
PS. My Ralliart uses 53610010. It's a great ROM, I love it. Runs well. In a Ralliart.
Edit: No, it's impossible. I'm just mis-reading the original post text, surely...
Old Dec 10, 2011 | 10:59 PM
syncmotion's Avatar
Yes I'm using actual Ralliart Rom flash to my Evo, with a proper tune I was making 225kw @ the wheel 53610010 is the latest Mitsubishi Australia using to update most Evo x that i was told
Old Dec 11, 2011 | 04:21 AM
tephra's Avatar
no the most recent update for 2008/2009/2010 AUDM EvoX MR = 53050012, however 53050009 is the best supported..
using an RA ROM on an evo is just asking for trouble... who tuned it?
Old Dec 11, 2011 | 01:33 PM
syncmotion's Avatar
Mine is not an MR it was GSR with sst
Old Dec 11, 2011 | 05:14 PM
tephra's Avatar
same thing when it comes to ROM's...
you need to run 53050009...
Old Dec 11, 2011 | 06:36 PM
syncmotion's Avatar
Where can i find 53050009 Rom?
