Innovate LC-1 logging AFR via ECU
Old Mar 11, 2012 | 02:13 PM
08GsrX's Avatar
So recently me and a friend hooked up my Innovate Lc-1 WB, We spliced into the yellow wire under the passenger seat and ran our power and ground up under the glovebox. We did the free air calibration and judging by the LED flashes everything went the way it should.
I went into the LM Programmer and made sure Gasoline 14.7 was selected and switched the Analog out 2 options to the following: 0.00V = 10.00AFR 5.00V = 15.99AFR.
Then went into EvoScan and went under the Wideband options and selected the LC-1 option and also made sure I had the right COM port selected. I went down to the bottom of EvoScan and clicked the LC-1 AFR option so it would log it along with a few other things like boost, throttle, knock and such.
Now this is the problem, I let the car warm up and hit start datalogging and my AFR is just stationary at like 10.001585 or something like that, It doesn't move at all even if I rev.
I open up Logworks and it seems to be logging via serial perfect, at idle im sitting right around 14.7 so I think thats accurate?
So what am I doing wrong? Why is my AFR not moving in EvoScan?
Old Mar 11, 2012 | 02:18 PM
08GsrX's Avatar
This is actually the exact number my EvoScan is showing for the LC-1
10.01171065
Old Mar 12, 2012 | 07:29 AM
08GsrX's Avatar
Anyone?
Old Mar 12, 2012 | 11:13 PM
RS200Z's Avatar
Assuming you tap into the correct yellow cable, then probably you got the logging address or formula wrong for your ROM ID in EvoScan.
Old Mar 13, 2012 | 03:11 PM
08GsrX's Avatar
Problem was in EvoScan, for the LC-1 I had "1" Bytes selected instead of "2".. Something so simple lol
evo4mad
May 5, 2015 06:22 PM
GreeceS13
Sep 24, 2014 12:25 AM
03Ev0luti0n
May 7, 2011 03:53 PM
stunt2
Apr 12, 2011 06:47 PM
evo9_jdm
May 7, 2010 09:04 AM
