MAPerformance 1000cc PNP injectors; Scale & Latency numbers!
Old May 2, 2012 | 11:40 AM
hollywood_X's Avatar
So we installed a set of new MAPerformance 1000cc PNP injectors into my buddy Pete's car and tuned him on E85. These are fantastically easy to tune and respond very well not much more to say so here are some pics and numbers.
Now for actual tuning numbers;
Scale; E85 609 and 91-93oct 812
Latency;
Code:
4.69     7.04    9.38    11.73   14.08   16.42   18.77
3.810   3.150   1.950   1.395   0.990   0.720   0.510
Attached Thumbnails MAPerformance 1000cc PNP injectors; Scale & Latency numbers!-img_0087.jpg   MAPerformance 1000cc PNP injectors; Scale & Latency numbers!-img_0089.jpg   MAPerformance 1000cc PNP injectors; Scale & Latency numbers!-img_0096.jpg   MAPerformance 1000cc PNP injectors; Scale & Latency numbers!-img_0102.jpg   MAPerformance 1000cc PNP injectors; Scale & Latency numbers!-map-1000cc-injectors-e85.jpg
Old May 2, 2012 | 12:11 PM
ChrisCarey's Avatar
Awesome, thank you sir!
Old May 2, 2012 | 12:17 PM
murlo26's Avatar
Huh, now you make Injectors? LOL
One stop shop I guess
Make a good 1500-1600cc injector and you will get many orders.
Old May 2, 2012 | 01:28 PM
mitsael's Avatar
Old May 2, 2012 | 02:08 PM
scheides's Avatar
EvoM Moderator
Whoah, fancy! Nice!
Old May 4, 2012 | 01:26 PM
Sadly I don't think there is much in that range to work with
Old May 8, 2012 | 11:42 AM
Bump!
Old May 8, 2012 | 11:50 AM
ChrisCarey's Avatar
Now available on our website
http://www.maperformance.com/product...=102572&page=1
Old May 8, 2012 | 11:56 AM
RazorLab's Avatar
Those look exactly like ID1kcc's, which are great injectors.
Scalings look exactly the same as well.
Old May 8, 2012 | 11:58 AM
murlo26's Avatar
^I am guessing the injector business is like almost anything else. You have like 2 HUGE companies (example bosch) that make everything then people simply rebrand them or modify a standard part. Which I think typically the bigger injectors are modified OEM ones.
That being said, to me its now a matter of picking the company you want to work with for the long haul. Both ID and MAP would be great choices in my mind.
Old May 8, 2012 | 12:07 PM
Kracka's Avatar
^Correct, the main two you have are Bosch and Denso.
Old May 12, 2012 | 11:38 AM
Yep
Old May 19, 2012 | 04:36 PM
scheides's Avatar
EvoM Moderator
Freaking good deal! My new choice for stock turbo or pump gas setups!
bbvc
Oct 24, 2011 04:59 PM
bbvc
04-06 Lancer / Ralliart Show / Shine
22
Apr 7, 2011 08:51 PM
Blacksheepdj
Lancer Troubleshooting
Apr 4, 2008 11:12 AM
vegasboy301
Jul 11, 2006 01:14 AM
vegasboy301
Jul 26, 2005 02:05 AM
