1000cc injectors good for 550whp on 93?
Old Dec 9, 2012 | 07:12 PM
sLowEvX's Avatar
Just trying to get an idea if my current injectors will be able to reach my goal.
Old Dec 9, 2012 | 09:55 PM
Smoochy's Avatar
Best bet would be to ask your tuner.
Old Dec 9, 2012 | 09:57 PM
itsmrrizz2you's Avatar
my friend made 560 at about 80% idc on c16 on the dyno a few nights go. anything past that and you will be out of injector like we were
Old Dec 9, 2012 | 09:58 PM
fic 1000's btw
Old Dec 9, 2012 | 10:45 PM
Darksun280's Avatar
What fuel pump setup? Also I thought fic only had 900's and 1100's for the X? If they are 1100's then you're fine. I'm using them and with a BR double pumper + fpr and I have fuel still at 30psi.
Old Dec 10, 2012 | 09:20 AM
sLowEvX's Avatar
Im running DW 1000cc, with a DW265 FP but will be removing the pump for a Walbro 400.
Old Dec 10, 2012 | 09:59 AM
momostallion's Avatar
the fic 1100s are rated for 604 bhp for 4 cylinder turbocharged applications.
(80% idc, 43.5psi)
Old Dec 10, 2012 | 11:26 AM
Darksun280's Avatar
(80% idc, 43.5psi)
I was at 52-55 base fuel pressure on my pulls.
Old Dec 10, 2012 | 11:46 AM
EDIT: nvm, just read your post above
what are you IDCs like at 605 whp?
Old Dec 10, 2012 | 02:07 PM
Darksun280's Avatar
Never logged them at 30 psi. I was at a dyno day. Been a while but I remember my tuner going over the numbers with me at like 4am while we were on the dyno one time. It was a 3rd gear pull. 10.8 to 11.1 A/f I was 81-83 IDC at 27-28 psi boost. My fuel pressure was the same 52-55 base. I was making 515 on a dyno dynamics at 9k.
Old Dec 10, 2012 | 03:07 PM
very nice. so i take it you run 14v to your pumps if your base is 55 psi base.
Old Dec 10, 2012 | 03:27 PM
Darksun280's Avatar
unfortunately yes.
Old Dec 10, 2012 | 03:56 PM
DocBoz's Avatar
i think youd be maxed out and be better off with 1100's or bigger
Old Dec 12, 2012 | 02:45 PM
murlo26's Avatar
I made 500whp on E85 and a double pumper with the DW1000's. I did have an AFPR with slightly raised base fuel pressure but not a huge bump.
On pump gas I don't see why you couldn't hit 550whp with them.
Old Dec 13, 2012 | 08:57 AM
sLowEvX's Avatar
Thanks all for the replies.
rafa.ralliart
04-06 Lancer Ralliart How To Requests / Questions / Tips
Oct 24, 2014 02:58 PM
cosworthevo1133
South Region
Jan 11, 2013 04:08 AM
tzoyi
Feb 20, 2012 10:31 AM
Spoolin4g63
Sep 23, 2011 08:40 AM
SPOOLEDTSiAWD
Mar 26, 2007 06:47 PM
