Need All tuners/ cobb people to help me!
Look at my first ****ing post lol I'm trying to help you but you didn't give me any info ... Try flashing a stock intake map if its still pig rich then check bpv (back to stock) if it leans out a lil over stock then you know the intake is installed correctly fuel trims should be within +-8
A person at cobb said 5 but There forum for beta maps shows 8 probably so every tom dick and harry are not emailing them everytime a fuel trim for and off the shelf map goes above 5 but you should have them as close to possible to zero so 5 would be better lol I currently have it to 0 to -3 weather has been crazy though, I like to error on the side of rich.
Two our cars run a maf and map sensor unlike most other cars .. The ecu will pick the lowest load value and use it so that might be the maf unill the bov releases all that wonderful metered air then instead of going pig rich and stalling the map sensor comes in and says ah this load makes more sense let's use this load instead ... Tons of posts about this
op problem looks to be either the bov which I can't really see or not installing the intake correctly. Log maf volts and maf g/s at idle
But I've been wrong before .. Hooking the stock bov back up should confirm the problem ... Stupid question but you did plug the empty hole in the turbo inlet where the recirculation hose went to right
so here's what I would do...
1Check the intake install with a fine tooth comb make sure everything is tight the maf is facing the correct direction and all the wires are still in there place
2Load a Cobb map that uses a stock intake this will reset the fuel trims
3Turn it on and see how the car runs use the Cobb to monitor ltft used or current what ever Cobb calls it
If the car still runs like **** put the stock bpv back on reset ecu via Cobb so trims are reset and run it again
4if it still runs like **** put the stock I take back on. Reset ecu.
5still running like **** I'm out of ideas with out being there.
Could be fuel pump relay that normally fails open failed close so its constantly on the full voltage would explain why fuel is good at wot but bad at idle ..
nj1266
125
Jan 12, 2010 07:37 AM
Clipse3GT
40
Oct 17, 2009 08:26 AM
