Help with open loop
Old Mar 8, 2013 | 05:25 AM
marinos's Avatar
Unhappy Help with open loop
Hi
My rom is 52500010 when i make changes to high octan fuel map it has difference only at close loop, how can i change the open loop maps? i need another tables? where can i find them?
thanks in advance
Old Mar 8, 2013 | 07:32 AM
momostallion's Avatar
you may have your terms backwards. open loop is what your are in when you go WOT (or anything over a certain load limit). closed loop is your "regular" driving.
changes to the high octane fuel map only effect open loop fueling.
there is no map to change your fueling in closed loop. closed loop is ecu controlled via the car's narrow band front o2 sensor to chase stoich air fuel ratio.
what are you trying to do?
Old Mar 8, 2013 | 10:43 AM
marinos's Avatar
I make changes to high octan fuel map but it doesnt make any difference in afr
Old Mar 8, 2013 | 11:27 AM
what rom is 52500010? euro ralliart?
what area of the high octane fuel map are you changing?
do you have a wideband? are you logging it?
Old Mar 8, 2013 | 11:36 AM
marinos's Avatar
i have a turboed lancer 1.8L, 52500010 is my rom, i have wideband but i don't log my programmer tryed yesterday to change the high octan fuel map but the afr didn't change
Old Mar 12, 2013 | 01:34 PM
marinos's Avatar
i change the lamda target in high octane fuel but the afr dosn't change does anyone know to help me? i can post you the xml and my stock hex if you need
stunt2
Sep 17, 2014 06:56 AM
EE
Dec 26, 2012 09:43 PM
EvoPower81
Dec 22, 2012 06:38 PM
C00LM4N
Dec 15, 2012 04:50 AM
SnailSpeed
Oct 22, 2012 10:00 AM
