Innovate LC-1 (No gauge)
Old Mar 18, 2013 | 06:37 PM
AWDTerror's Avatar
I finally just got done with installing this. Absolutely the biggest pain to setup if you don't do your research.
Remember these things:
Baud rate: 19200
and make sure you set the AFR/Voltage values to 10 to 15.99 or it won't read right in the Accessport.
Also to note: There is only a .4 difference between the Prosport Evo WB and the LC-1.
Old Mar 18, 2013 | 07:30 PM
Rokpapaziz's Avatar
Hi
A friend fitted my LC-1 to my Ralliart on the weekend. What is this Baud rate for?
I'm using a Tactrix and not an AP, so not sure if this applies to me.
Still have to do the LM programmer but so far the gauge seems to be reading pretty close to correct (on idle my AFR sits on 14.4)
Old Mar 18, 2013 | 07:42 PM
AWDTerror's Avatar
Baud rate is the data transfer speed (basically) between the computer and the LC 1 if it is not set to 19200 it won't connect.
Old Mar 18, 2013 | 10:25 PM
Rokpapaziz's Avatar
^^ Cheers for that! Will try it out
Accursed
14
Jun 6, 2013 08:14 PM
desiromeo812
Apr 30, 2012 05:48 AM
dan l
May 15, 2008 07:02 AM
mrfred
16
Apr 26, 2008 08:57 AM
gosu.pianist
Feb 21, 2008 06:16 PM
