The definitive way to tune an evo X
Old May 15, 2013 | 09:42 AM
hispanicpanic's Avatar
before you flame me, yes i have searched. There is so much damn misinformation. So many different programs, so many different tools, it is honestly a bit overwhelming. I need help.
From what i gather, there are 4 separate programs/mods you have to buy in order to tune...
1) Program/device to flash a map onto an ECU
2) Seperate Program & extra mods needed in order to log the data you need to tune
3) Seperate program & a laptop to read the data and turn it into a power curve (taken care of by a dyno computer in the case of a pro tune)
4) Seperate program & a laptop to make changes to data tables obtained in 2
I'll start by going into questions and Issues with each of the 4 above
  1. So there is cobb AP, ECUTEK, and atleast a handfull of other options. Each locks your ECU to that device. None are comprehensive, and some require a laptop. If you buy an evo that is locked, you're ****ed. Time to buy a new ECU.
  2. Cobb AP - great idea, terrible execution. I don't wanna pay for a device that's more expensive than a tablet only to use it once or twice.
  3. I'm not a ****ing programmer. I don't want to deal with open source stuff i have no idea how to use.
  4. I want to be able to switch maps easily on the fly. No, i don't want to forfeit my cruise control button as some open source programs allow. I want a separate switch for this.
  1. I have found zero information on the exact type of data you can log without adding sensors/guages (lots of stuff for evo 8&9 but X stuff is sparse). Exactly which parameters can you measure in stock configuration? Some parameters important to me - Intake air temp, Pre IC air temp, Manifold Air Pressure, knock, AFR
  2. What sensors do i need to add in order to log enough data to tune properly? I'm assuming a wideband o2 sensor. Also, whats the deal with all these o2 sensor deletes?? Some people require a legal emission car.....
  3. Again, there are so many damn programs out there that can log data. Which one should i choose and why???? Evo scan seems to be the most popular, and since it can load onto a tablet, it makes turning your radio into a tablet a very attractive option (think GTR guage capabilities).
  1. Thinking of Virtual Dyno here. Can any other programs do this? The less programs i have to download and maintain the better. I think its bull**** i have to have 3-4 different mods/programs just to tune a car. Makes a megasquirt sound incredibly attractive considering it costs almost the same as a cobb AP and is way more capable......
  1. Again, the less programs i need the better, but i don't want to sacrifice functionality and user friendliness. There are so many damn programs it seems to serve this function it isn't funny. Which should i choose, and why? Keep in mind, i have no interest in open source bull**** i need linux in order to upload or open.
As you can see, i need a complete comprehensive solution to tuning. If there is one, it isn't easy enough to find. The idea of replacing the radio with a Tablet is incredibly attractive if you can use it to log, flash ecu, load maps on the fly, play music, display a custom guage layout, & upload/download maps via USB.
Also, i want to create some sort of alarm in conjunction with a kock sensor. Where it plays a noise & flashes your guage different colors when it senses 'X' counts of knock.
I'm tired of digging through 30 pages in a thread just to come up empty handed or only find 1 or 2 bits of useful information. So for the sake of this thread and others who may stumble upon it, please keep the posts to a minimum unless you can significantly contribute.
Old May 16, 2013 | 05:41 AM
Daluv's Avatar
it really comes down to that:
A) You pay, go to a tuner and do not think: ecutek, Cobb
B) You do not pay but you need a brain and time: ecuflash, evoscan, VirtualDyno
Mart
Old May 16, 2013 | 09:38 AM
Mart
Is there any way i can consolidate any of those? Has anyone tried to turn their carputer or tablet into a tuning/flashing device?
Old May 16, 2013 | 05:04 PM
Gyroscope's Avatar
Whats the benefit of ECUTEK, the FQ300, 330, 360, 400s all are tuned on ECUTEK, why?
Old May 16, 2013 | 05:09 PM
Daluv's Avatar
FQ are uk based. Ecutek is uk based.
same result can be achieved with Opensource, Cobb or any other solution using the stock ECU.
Mart
Originally Posted by Gyroscope
Whats the benefit of ECUTEK, the FQ300, 320, 360, 400s all are tuned on ECUTEK, why?
Old May 29, 2013 | 01:07 PM
fostytou's Avatar
EvoM Community Team
My notes in bold:
1) Program/device to flash a map onto an ECU - Tactrix and ECUFLASH work
2) Seperate Program & extra mods needed in order to log the data you need to tune - Evoscan can read default MUT stuff, you can add more with mode23
3) Seperate program & a laptop to read the data and turn it into a power curve (taken care of by a dyno computer in the case of a pro tune) - EvoScan can do this but its not as good as virtualdyno or a real dyno
(taken care of by a dyno computer in the case of a pro tune) - any computer works in the case of ECUflash
  1. So there is cobb AP, ECUTEK, and atleast a handfull of other options. Each locks your ECU to that device. None are comprehensive, and some require a laptop. If you buy an evo that is locked, you're ****ed. Time to buy a new ECU.No, you can unlock and write to an ECU but the device / license might be worthless then
  3. I'm not a ****ing programmer. I don't want to deal with open source stuff i have no idea how to use. Then why are you asking? To just flash a ROM from an e-tune you don't need to know how to do anything other than hit install (or nothing if you want a pro to do it)
  4. I want to be able to switch maps easily on the fly. No, i don't want to forfeit my cruise control button as some open source programs allow. I want a separate switch for this. You don't forfeit your Cruise button with tephramod, you add a second purpose to it. You can also use a mechanical switch or TPS before startup if you prefer.
  1. I have found zero information on the exact type of data you can log without adding sensors/guages (lots of stuff for evo 8&9 but X stuff is sparse). Exactly which parameters can you measure in stock configuration? Some parameters important to me - Intake air temp, Pre IC air temp, Manifold Air Pressure, knock, AFRAnything a normal that you could log with a standard OBDII tool and then some. Check out evoscan for more info or look at the MUT listing in the stock ECU tuning wiki
  2. What sensors do i need to add in order to log enough data to tune properly? I'm assuming a wideband o2 sensor. Also, whats the deal with all these o2 sensor deletes?? Some people require a legal emission car..... Just a wideband, but if you are getting a protune they'll have a tailpipe sniffer and you won't need one. Eliminating an O2 has many purposes that you can read about and there are still ways to keep the car emissions compliant
  3. Again, there are so many damn programs out there that can log data. Which one should i choose and why???? Evo scan seems to be the most popular, and since it can load onto a tablet, it makes turning your radio into a tablet a very attractive option (think GTR guage capabilities). Evoscan is probably the most comprehensive and widely configurable. If you want someone who is developing to get you the latest and greatest its just not going to happen, you'll have to read and learn yourself or find a smart friend
Just because you *can* do everything with one tool doesn't mean you *should*. Applications that try to do everything usually suck, especially when people are developing them for free and as a small developer audience
Why so angry brah? Chill out. Ecuflash will do everything you want at your skill level right out of the box. If you want something that is prettier you can pay for it, but you'll continue to pay for it with less support, less customization, and future costs.
Why? How often is a newb going to be changing maps? You said yourself once or twice - got a map switch? Make that once.
Also, i want to create some sort of alarm in conjunction with a kock sensor. Where it plays a noise & flashes your guage different colors when it senses 'X' counts of knock. Tephramod can flash your CEL for knock. Thats about all you are going to get unless you learn A LOT (that you say you aren't willing to learn)
If you are tired of it, then just give up and pay someone to do your tune. It really isn't that hard to do a basic tune, but you seem completely unwilling to learn and expand your knowledge. If you were experienced enough to tune yourself, you wouldn't be asking these questions.
That said, I encourage you to learn, grow, and understand your vehicle. Those who just fork over money might not know what they are getting themselves into.
Old Jul 9, 2013 | 06:57 AM
CincyEvoX's Avatar
Either way you go (Pay tuner / Tune yourself) get some dyno time so you can safely measure your progress. Don't be one of the guys drag racing down some back road for the seat-of-the-pant-o-meter.
Old Jul 9, 2013 | 04:16 PM
btack's Avatar
Haha, the easy way to tune your evo..? There's only way to tune yourself and it involves lots of studying. Only other route is to pay to play, a tuner that is.
If you take a good month or 2 studying Merlins guide to tuning a evo x while cross referencing all cobbs tuning guides you will figure it out. "ALL" not just the evo ones. There good info in all of the guides, some are just more in depth than others. There is tons of other good info online. Read, read, read, then read some more
Good luck
Kalivar
12
Oct 19, 2012 07:07 PM
silver_evo
Jun 25, 2010 11:31 AM
DRAG
24
Jun 11, 2009 10:10 PM
shunderwunder
Apr 1, 2008 05:38 PM
JordanS4
Feb 3, 2008 05:43 PM
