P1876: Gear block 1st
Old Jun 14, 2013 | 08:32 AM
mel1888's Avatar
Hi guys
Has anyone encountered this fault code before? P1876: Gear block 1st.
What does this mean tho and what needs to be done.
Trying to find out some before visiting the mech.
Thanks in advance!
Old Jun 14, 2013 | 08:30 PM
ikt's Avatar
ikt
wrong account
Old Jun 14, 2013 | 08:35 PM
ikt@evoxpod.com's Avatar
Originally Posted by mel1888
Hi guys
Thanks in advance!
your transmission is toast
however, check and make sure your MAF sensor is functioning okay. I've read about it a bad MAF sensor causing that code.
Use a tuning program to monitor your MAF voltage. If it's "0" all the time, then replace it, clear the codes, see if anything pops up.
If the MAF is okay....then you're looking at a transmission repair.
doghouse
10
Jul 10, 2016 04:19 PM
Redefined
Mar 2, 2016 04:57 PM
jdyck81444
Oct 4, 2015 06:28 AM
krisiun
Oct 11, 2011 03:27 PM
Gary@MellonRacing
Aug 31, 2010 04:43 PM
